- Thank you received: 8
Bike idles down and dies once it's warmed up
- rcook52459
31 May 2012 23:42 #526229
by rcook52459
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
Replied by rcook52459 on topic Bike idles down and dies once it's warmed up
when one of coils get warm it shorting out?seen it happen in cars
- Ricky318i
03 Sep 2014 12:38 #646126
by Ricky318i
Replied by Ricky318i on topic Bike idles down and dies once it's warmed up
grendel, Have you managed to sort this one out?
I believe I have a similar problem with my KZ250, It runs for a few minutes and then bogs down, loses power, stops idling and dies. It will happen intermittently and without warning. I suspected the coil, or something else in the ignition circuit. I am not certain where to start faultfinding this.
- Thank you received: 2098
03 Sep 2014 19:16 #646173
by Patton
If not already done, would check valve clearances and assure clearances are within specs.
Insufficient valve clearance (i.e., too tight valves) may result in the reported symptoms.
Replied by Patton on topic Bike idles down and dies once it's warmed up
Ricky318i wrote: grendel, Have you managed to sort this one out?
