pilot jet plug????
- garyprather
Re: pilot jet plug????
27 Mar 2012 11:01
I have no plugs nor o rings placed under my pilot jets. I was looking to buy them. I was going to replace my mixture screw o rings also. I hope putting the plugs in will alow me to move my mixture screws to a normal settings of 1 to 2 turns instead of 4 to 5.
- mtkawboy
27 Mar 2012 18:59
cycleorings.com has complete o -ring kits for those carbs for around $15 but you still need the plugs
- gengomerpyle
27 Mar 2012 19:22
mine are the same way
mtkawboy wrote: The 34 Cvs on my 82 GPZ 750 have aluminum plugs with flat o-rings {not rounded, flat on top & bottom }on top or bottom with carb upside down instead of the normal rubber plugs. Is this the o-ring youre seeing ?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- roy-b-boy-b
28 Mar 2012 10:23
Rob at Z1E suggested the rubber plugs as other brands use them instead of the aluminium plugs.
28 Mar 2012 10:38roy-b-boy-b wrote: Rob at Z1E suggested the rubber plugs as other brands use them instead of the aluminium plugs.
Good info!
Guessing the rubber plug would also eliminate need for the o'ring.
Perhaps the rubber substitute is one of these type plugs?
www.z1enterprises.com/Carb-Rubber-Passag...ug-4-Honda-1963.aspx
www.z1enterprises.com/Carb-Rubber-Passag...nda-GL1000-1961.aspx
www.z1enterprises.com/Carb-Rubber-Passag...uki-Yamaha-1962.aspx
Have wondered about, but never tried, pressing a small fishing line lead weight into the area.
- grant_stl
28 Mar 2012 11:02
The rubber plug is fine to use. They are 4.50 a pair at this link.
www.mikesxs.net/product/48-5002.html
They are better than the aluminum ones with the O ring.
Your mains are way to rich. My setup is below for my 83 1100 Spectre, and am still fine tuning it but am very close.
K&N RU-0984 pods
pilot 42.5 (too rich dropping to 40)
Mains 137.5 (close, possibly a touch on rich side)
Needles 5IX11 (5 notch adjustable)available here www.mikesxs.net/product/48-0663.html
K&N RU-0984 pods
83 KZ1100 Spectre, St. Louis elevation 500 ft.
K&N RU-0984 (pods)
4 into 1 Header
Pilots 40 1.5 turns out
Mains 135 (cylinders 2 and 3)
Mains 132.5 (cylinders 1 and 4)
Needles 5ix11 set on clip 2
K&N RU-0984 (pods)
4 into 1 Header
28 Mar 2012 11:27grant_stl wrote: The rubber plug is fine to use. They are 4.50 a pair at this link. www.mikesxs.net/product/48-5002.html They are better than the aluminum ones with the O ring....
Thanks, grant_stl!
The Yamaha plugs at Mikes appear to be the same as these at Z1E :
- mtkawboy
28 Mar 2012 14:22
An 83 GS1100 Katana I bought had the tips of rubber gloves stuffed in the holes. I do not advise this method
- nedrowjoe
28 Mar 2012 16:20
I know I spent a hell of alot of time re-jetting my bike last year. I wanted to learn how to work on carbs. I spent time drilling out and using .5 mm washers on the needle jets to shim the needle, my csr only has 1 clip position. I also removed the plugs your talking about because some people said they didn't matter. I could not get her right and contemplated ghost riding it off a cliff, it was pissing me off. I decided f it and tore the carbs apart once again and put those plugs back in and It's been running right ever since. I say find those plugs put them in and try your set up before you adjust anything else. It could be as simple as putting them back in. I also found its better to change only 1 variable at a time, meaning dont put the plugs in adjust the needle shim, change main and pilot jet all in one adjustment. If you adjust one thing and it gets better you headed in the right direction, if you adjust 3 things and its worse, how do you know what is good and what is bad. It will take more time but in the long run you may actually save time and money and not ghost ride your bike off a cliff. Good Luck!
- garyprather
30 Mar 2012 13:34
I agree with one thing at a time I will be ordering those rubber plugs and trying it out. If I run into a rich problem due to the 160 main then I will order some smaller ones.
- Polar_Bus
30 Mar 2012 14:37garyprather wrote: Can anyone tell me where the best place to order the pilot jet plugs and some fuel mixture screw O rings from. I was on kawasaki.com and they are wanting 50 bucks for 4 of each. There must be a cheaper place?????
GS1100 carbs are the same. The Suzuki p/n for the rubber pilot plug is 13357-44080 $3.14 ea.
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
30 Mar 2012 15:05Polar_Bus wrote:garyprather wrote: Can anyone tell me where the best place to order the pilot jet plugs and some fuel mixture screw O rings from. I was on kawasaki.com and they are wanting 50 bucks for 4 of each. There must be a cheaper place?????
