More carb problems. 1982 Spectre 750
- jon_570
1982 Kawasaki Spectre 750 N1
- jon_570
- jon_570
- JR
- Thank you received: 449
- Thank you received: 2098
JR wrote: ... a case of checking for spark, fuel and compression....
If #2 and #3 spark plug wires are long enough, could swap them to see whether the misfire moves from #2 to #3.
This could help with further diagnosis.
Could also remove the spark plugs;
hold #2 and #3 plug bases against the engine head;
turn ignition switch ON;
spin over the engine;
observe for fat blue sparks while engine is spinning over.
Assurance of fat blue spark is a good place to begin diagnosing lack of combustion within a cylinder.
When finished testing for plug spark, remember to turn the ignition OFF.
- jon_570
- jon_570
- jon_570
And would also re-test using a brand new NGKB8ES spark plug in #2 cylinder. Because sometimes a plug will fire okay outside the cylinder, and then won't fire when installed.
This should hopefully rule out possible issues with either spark or compression in #2 cylinder.
- jon_570
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Get a good spray carb cleaner.
Take the little straw and cout one end off at a 45 degree.
Remove all your rubber shit from the carb and all jets/mix screws etc.
Re-insert the mixture screw (if applicable) without its ruber oring, and set it to default position.
Using the spray cleaner and straw, put the straw all the way down inside the pilot jet hole taking note that the open 45 end is facing the direction of the jet passage/tube cut into the casting.
Spray the cleaner like this while looking into the bore of the carb, and you should see a nice even squirt of carb cleaner coming out of all the small pilot holes in the carbs bore.
Repeat this for all the carbs, taking note to assure they all spray the same.
Best to follow with 100psi of compressed air if a clog is found - and the 45'd straw can be used to shoot cleaner backwards into bore holes as well!
This is the only sure fire way to KNOW that the fuel is doing the same thing as the cleaner when your running the bike.
I also have a set super small drill bits that I use as feeler guages to mae sure that knowone has tampered with the air jets on the intake side of the carbs - assuring they are all the exact same size.
Good luck! -and make sure there arent any air leaks.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Motor Head
- Thank you received: 391
