Manual fuel valve option
- kretchman
Re: Manual fuel valve option
14 Sep 2016 04:09
This might be a dead thread, but I'm looking for some info as I have 2 problems. I'm running a zephyr 750/810 with CR29 carbs. Now the cr29's don't have vacuum ports for the stock petcock, which is fine, because the stock petcock also clashes with the new carbs.
I need a really small petcock solution which is manual (no vacuum) and potentially has 2 outlets, but most importantly clears the carbs.If it's a single outlet I could use a splitter to feed the carb rail.
I'm not certain on the spacing of the bolts, but the part is 51023-1267 and apparently interchangable with EN500 Vulcans and I'm sure a bunch of other bikes.
I'm getting the holes measured tonight so will post back, but I'm wondering if anyone running a Pingel or a Golan valve can share the dimensions of the valve / adapter plate used? It's going to get real tight so I'd love some certainty before dropping $100 on what are hopefully the right parts.
Cheers beers,
BK
Attachment 14292471_10210525417631336_1229711275215116023_n-edit.jpg not found
Attachment 12511767_10156374198215463_1053187323_n.jpg not found
Cheers beers,
BK
There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
- kretchman
14 Sep 2016 04:38
confirmed 34mm spacing. What options are out there?
14 Sep 2016 05:12 - 14 Sep 2016 05:43
I saw a Pingel dual outlet fuel valve on eebbaayy listed for the Yamaha Raptor, but it had a single fuel pickup, so you wouldn't have a reserve. Here are a few single outlet that I've saved in my favorites. some extend further down from the tank than others. .... eebbaayy search = Yamaha raptor fuel valve. or warrior. or banshee. etc.
Yamaha Banshee. fuel outlet = 8mm. Japan.
Yamaha Raptor. Japan. bolt hole spacing? probably 34mm.
universal fuel valve
Last edit: 14 Sep 2016 05:43 by martin_csr.
The following user(s) said Thank You: kretchman
- kretchman
15 Sep 2016 23:51
As space is so tight, I went with the smallest option I could find. The pingel even looked too big. Will have a custom adapter plate made to suit. Plus these Golan are slick units with a ball bearing mechanism in the switch
Kills me that it's for a harley, but I just think of it as universal
www.revzilla.com/motorcycle/golan-click-...t-petcock-for-harley
16 Sep 2016 05:18 - 16 Sep 2016 05:18
That first one I linked fits up close to the tank & it's 34 mm. seems like that would've been a good choice, especially since it's an oem made in Japan part & no adapter plate needed.
Last edit: 16 Sep 2016 05:18 by martin_csr.
- 750 R1
16 Sep 2016 05:46
Hello Martin, do you know if those "murphs manual conversion kits" are still available...?
16 Sep 2016 06:36
I guess so, as it's still listed on the site. click Concours there on the upper left, then click fuel system.
I don't know if the kit is suitable for KZ or other petcocks. The ports on the Concours may be oriented differently or something. ???
The following user(s) said Thank You: 750 R1
- baldy110
16 Sep 2016 09:43 - 16 Sep 2016 09:46
I had the same issue with my RS36 hitting the petcock. Here was my solution and pretty cheap. I cut up the original petcock and used the base. I epoxied the hole left over from removing the valve assembly. I poured in some fuel tank liner to seal the epoxy from the gas. I tapped a hole for a 90 degree barbed fitting on the side of the base. I put on a short tube onto the barbed fitting to an on / off valve petcock which I epoxied onto the bottom of the tank. From there a gas line to the carbs. I have no reserve but it is simple and inexpensive.
Last edit: 16 Sep 2016 09:46 by baldy110.
