bike wont start cold
28 Nov 2011 18:14 #490541 by silentchris
bike wont start cold was created by silentchris
i just tore my stock carbs down bench synced set fuel levels via the wet method. it started yesterday first kick but today it wont start cold popped it with some either it fired and idled let it warm up a bit killed it gave it a couple minutes and it started right up any ideas would be appreciated
Speed is only a question of money. How fast do you wanna go?
1978 kz1000 ltd
Hailing from the wild suburbs of our nations capital
  • mark1122
  • Keep twisting it
28 Nov 2011 19:01 #490551 by mark1122
Replied by mark1122 on topic bike wont start cold
id say its not getting enough fuel.
maybe u have some dirt in the choke or idle circuit or float valve ??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
28 Nov 2011 19:42 #490560 by silentchris
Replied by silentchris on topic bike wont start cold
I noticed a drip from the #3 carb. I probably flubbed setting the float back apart they come. If o
Its not right this time im sending them to redline.
1978 kz1000 ltd
28 Nov 2011 20:28 #490565 by P21
Replied by P21 on topic bike wont start cold
remember the carbs MUST be LEVEL when you clear tube test it
how does your air box look or smell of gas?
Kawasaki KZ 1000 Police (2002) P21
28 Nov 2011 21:01 #490570 by silentchris
What airbox:-) I have pods they're sitting on my toolbox. I had it level these carbs are beating me up
1978 kz1000 ltd
  • DoubleDub
  • Visitor
28 Nov 2011 22:13 #490577 by DoubleDub
Replied by DoubleDub on topic bike wont start cold
Did you check the petcock/fuel tank for sediment? Clean inline filters? If it ran fine one day, then not the next I would bet it's fuel supply related.
  • lemo32
  • The Price of Cool aint cheap
28 Nov 2011 23:11 #490588 by lemo32
Replied by lemo32 on topic bike wont start cold
Was cold starting an issue before rebuilding the carbs? I would look into a valve adj, maybe run a compression check but would for sure run the over head.
1979 kz 1000 06 katana 750
28 Nov 2011 23:20 #490589 by silentchris
Before starting fluid would get it to fire it wouldn't idle its quite nice sounding when running definitely has good compression I guess ill check the timing maybe the advancer is sticky I've seen cars do that
1978 kz1000 ltd
  • Motor Head
28 Nov 2011 23:20 #490590 by Motor Head
Replied by Motor Head on topic bike wont start cold
silentchris wrote: What airbox:-) I have pods they're sitting on my toolbox. I had it level these carbs are beating me up
Were you Air-filters on when you were trying to Kick Start Cold?
28 Nov 2011 23:25 #490593 by silentchris
No air filters on. Will that help?
1978 kz1000 ltd
  • Motor Head
28 Nov 2011 23:31 #490595 by Motor Head
Yes, try that. it will create more signal in the venturi of the Carb. Also you should leave the Throttle closed.
Have you re-adjusted the jetting for the Pod's? Or are they just going on now?
28 Nov 2011 23:42 #490601 by silentchris
It has stock jets bike came with pods and kerker. These carbs are way more sensitive than any single car carb.
1978 kz1000 ltd
