Kz400 carb holder options?
- uglee
- New 2da game but Tru 2this thang!!!!!
Re: Kz400 carb holder options?
27 Nov 2011 23:17
I don't think they will be the correct height.... Would it make a difference?
28 Nov 2011 01:02uglee wrote: I don't think they will be the correct height.... Would it make a difference?
Holes in a carb holder must match mounting studs on the engine head (center-to-center distance between studs should equal center-to-center distance between holes in carb holder).
Inside diameter of the holder must be sufficiently adjustable in order to snugly tighten around the outside diameter of the carb.
- loudhvx
28 Nov 2011 04:56
Also, notice the center-to-center line of the mounting holes is offset by 3mm from the center of the bore. (in the diagram I posted)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- uglee
28 Nov 2011 11:33
The ebay holders are way too short....... Back on the junkyard hunt tomorrow!whippeeeeee
28 Nov 2011 15:17 - 28 Nov 2011 15:20Patton wrote: ...From the listing:
...LAYING FLAT MANIFOLD IS 25 MILLIMETERS TALL...
AVAILABLE IN 60mm, 70mm & 75mm CENTER TO CENTER BETWEEN STUD / BOLT MOUNT HOLES....
uglee wrote: The ebay holders are way too short....
Wonder how tall are the oem carb holders?
Wonder if the ebay carb holder has sufficient distance between the mount holes (appears to need an additional 1.3 mm), or enough material to elongate each hole?
Wonder if the ebay holder has the needed 3mm offset below center-line between mount holes?
Unfortunately, the drawings of Mikuni's offerings appear not to have the needed 3mm offset below center-line between mount holes.
Last edit: 28 Nov 2011 15:20 by Patton.
28 Nov 2011 15:25
Any details available as to diy construction of the metal flange?
And source/type of sufficiently large "heater" hose?
- uglee
29 Nov 2011 00:56
Well guyz looks like i'll be going with part 16065-1135{thanks Chris from z1}..... So now is the price hunt... Anybody git 2 carb holders for a kz1000p cheapers than 30 bucks? Dont need 4 that z1 offers at $60 but that is a good price. Gonna check the dealer first thing in the morning.
- uglee
08 Apr 2012 01:20
Was scared to rig up the holders so today got lucky with a set off ebay!! Carbs cleaned again waiting 2 fire the lil scot up in da morning(fingers crossed).....
- loudhvx
02 Jul 2019 19:01 - 02 Jul 2019 22:09
Reviving this thread since I'm now working on a couple of early Kz400's.
I'm simultaneously trying to get a 75 D2 and 77 D4 up and running. Both were very cheap and in rough condition.
I'm revisiting the differences between the early motors with piston CV carbs and the early motors with diaphragm CV carbs.
They use different carb holders and I also notice a slight difference in the head casting. I'm not sure the head casting difference exactly correlates to the different carb types or not. (As opposed to the later style motors which all used diaphragm CV carbs.)
I can't find any precise measurements for the diaphragm-CV carb holders. So that will be one of my first steps. I can then add that to my other graphic.
When I get a few photos and maybe a vid, I'll post them in a project thread.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 02 Jul 2019 22:09 by loudhvx.
- loudhvx
09 Jul 2019 07:09 - 09 Jul 2019 15:35
These might not be the final versions, but I thought I'd post what I have so far.
I will post a note if I change this info.
"Plate" refers to the racking plate the carbs are attached to.
Diaphragm carbs did not use a plate, they used steel-angle brackets.
Old-style motor:
1974 (D1) (Standard) : piston CV with plate, using 16065-037
1975 D(2) (Standard) : piston CV with plate, using 16065-037
1975 S(1) (Special) : piston CV with plate, using 16065-037
1976 D3 (Standard) : piston CV with plate, using 16065-037
1976 S2 (Special) : piston CV with plate, using 16065-037
1977 A1 (Deluxe) : piston CV with plate, using 16065-037
1977 D4 (Standard) : diaphragm CV no plate, using 16065-048
1977 S3 (Special) : diaphragm CV no plate, using 16065-048
1978 A2 (Deluxe) : diaphragm CV no plate, using 16065-048
New-style motor:
1978 B1 (Standard) : diaphragm CV no plate, using 16065-1002
1978 C1 (Special) : diaphragm CV no plate, using 16065-1002
1979 B2 (Standard) : diaphragm CV no plate, using 16065-1002
1979 H1 (Ltd) : diaphragm CV no plate, using 16065-1002
This port diagram and holder diagram applies to the older-style motor only.
If someone wants to confirm the bolt angle through actual measurement, that would be great. Calculations can be off more than actual measurements.
Old-style motor:
New-style motor:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 09 Jul 2019 15:35 by loudhvx.
- loudhvx
09 Jul 2019 07:22
Here's something curious that I've noticed. The early style motors have at least two different head castings. The main difference is how the carb-holder boss is cast into the head. Another slight difference is the valve-lash window plug. Some motors have a very large hex while others have a smaller hex. But I can find the smaller hex on both types of head castings. I don't think the differences affect anything functionally. Maybe Nebr_Rex knows otherwise.
1981 KZ550 D1 gpz.
Other links.
Other links.
The following user(s) said Thank You: TexasKZ
