- Thank you received: 385
Dynojet kit or not?
- ThatGPzGuy
My question: Is the dynojet kit worth it? Or should I save my money and just fatten up the main a bit and be done with it? Stage one or two If I do decide to go with the kit?
TIA,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2098
- wireman
- Thank you received: 299
- ThatGPzGuy
I agree. I don't know how much of it is dirty carbs vs. the 4 into 1 but I figued while I had the carbs out... I just want to know if the kit is worth it.Patton wrote: Would bear in mind that the reported issues likely didn't exist when the bike was new and running with its new carbs.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ThatGPzGuy
wireman wrote: save your money,did you do anything to the carbs to compensate for the header?
No it still has the stock jetting. One of the reasons I thought I would need kit would be the 4 into one and the K&N which I have not installed. Granted, I do need to tear them down for a good cleaning. This is one of of those "while I am at it..."
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- Old Man Rock
- Thank you received: 225
Seriously speaking, to start this pig on a cold engine required holding the starter switch for 60 seconds to even get an indication she would kick over... :blink: No joke! Richard also stated this thing had no power.... Had a nasty little ticking sound that turned out to be a missing vacuum cap...
We were going in for a head gasket(s)/O-ring change (nasty oil leak), valve clearances and carb adjust sync. To start with....
Combustion Chambers: Caked with dry carbon build up.... Shit, this crap was 1-2mm thick.... :blink:
scraped and cleaned... Same with the piston domes... Miracle this thing even sparked at all....
Timing chain was off one pin... Ok, so yeah that would effect power... :S
Adjusted valve clearances (3 intakes didn't have the right size so going back in), 3 intakes still tight... buckets do rotate thankfully...
Carbs...
All 4 pilots where anywhere from 3/4 turn to 4 turns out.... :pinch:
Set all 4 at 2.5 turns out... Will get back to these adjustments after reviewing new plug conditions and reported operations.
Sync (Morgan ):... Holly crapola, #1 was at 40cmHg.... 2, 3 & 4 @ 0cmHg... :pinch: :whistle:
OK, once figured out the syncing on these carbs, all 4 @ 18-20cmHg... Rise and fall in unison w/in 2cmHg.... All good!
Found one missing Vacuum cap missing carb #2. RTV in rubber hose piece until cap can be obtained, all better.
Next morning, Re-torque engine bolts/nuts....
Pull choke, she started in ~ 5 seconds, purrered like a kitten.
Richards ride comment.... Whoa, a whole new bike.... Not to mention the shit-eating-grin on his face....
Sorry for the long story :blush: but I don't see any mentioning of a carb sync here, maybe my old eyes missed it... Might want to take a look at that as well for it made a HUGE difference in Richards police special...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- ThatGPzGuy
Old Man Rock wrote: I don't see any mentioning of a carb sync here, maybe my old eyes missed it... Might want to take a look at that as well for it made a HUGE difference in Richards police special...
OMR
I had the carbs synced and the valves adjusted about 1,500 miles ago. It runs OK otherwise but your point is well taken. It could use a tune-up.
Since I am going to tear the carbs down anyway I'll probably up the mains a bit. Anyone have an idea of how many sizes to go up? I understand a larger pilot is unavailable.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ThatGPzGuy
TIA,
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- koolaid_kid
- Thank you received: 99
And you absolutely MUST call Z1 and speak to a human. They are very knowledgeable and helpful, and you can ask and answer questions directly.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- P21
- Thank you received: 34
Please verify that ALL carbs fuel level is correct (clear tube test)
then move on to other things if not right
just saying from the past
Kawasaki KZ 1000 Police (2002) P21
