Jet needle improves acceleration.
  • LarryC
  • LarryC's Avatar
Re: Jet needle improves acceleration.
15 Nov 2012 10:21
#558453
:lol:
Here's the flow chart you really want...
Attachment image06.png not found
Larry C.
  • baldy110
  • baldy110's Avatar
16 Nov 2012 18:11
#558690
LarryC wrote: :lol:
I like it. In fact I will hang this quote in my garage.
  • donthaveakawman
  • donthaveakawman's Avatar
21 Nov 2012 21:49 - 24 Nov 2012 23:39
#559529
size 136 jets in there....needle-jet to say it does alright fool mileage seems to have increased;) .
Attachment 10172012001.jpg not found
Last edit: 24 Nov 2012 23:39 by donthaveakawman.
  • donthaveakawman
22 Nov 2012 04:23
#559582
so, I noticed the following 4 cylinder kz models, when researched have the following hp to bore x stroke ratio's, all being oversquare(bore larger than stroke)
-80 kz550 fx makes 58hp, 58x54
-80 650 f, about 64hp 62x54
-80 750 l 74hp 66x54
-80 1000 ltd 95 hp 69x66
-2004 z750 68x50 100 hp
-2004 z1000 77x50 127hp
so if the larger bore makes bigger hp per cc vs torque then why mess around.
  • bountyhunter
  • bountyhunter's Avatar
22 Nov 2012 04:52
#559584
I still like the sign I saw back in the deep part of the shop at Grand Prix Kawasaki:
SHOP LABOR RATES:
Basic Rate: $60/hr
If You Watch Me Work: $150/hr
If You Worked On It First: $300/hr
  • donthaveakawman
22 Nov 2012 07:59
#559588
SHOP LABOR RATES:
Basic Rate: $60/hr
thank you, that is funny
  • baborz72
  • baborz72's Avatar
  • Not enough hours!
06 Jun 2013 09:01
#591052
Hi. I have this very same bike with thew very same problem.I put pods on and fabbed a 4-2-1 header. It is very lean during the mid and was lean on the top, but not as bad. Ran a 125 mainjet and she's too fat. Going back to a 120 main and going to run a different needle. I turned my needles down by hand and it got significantly better, but I screwed the off-idle up. I am convinced that I am on the right track with a needle swap. Going to run a 5FL14. I will post the results.
It'll go...or...It'll blow!
  • nads.com
  • nads.com's Avatar
06 May 2014 19:09 - 06 May 2014 19:10
#631593
Does it idle smooth and steady? Are all plugs th same color now? You never said how It runs at idle now, was just wondering if you have a plug cap that is bad.
Last edit: 06 May 2014 19:10 by nads.com.
The following user(s) said Thank You: Tomolu5
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
18 Mar 2016 15:37
#716073
Patton wrote: For carb tuning considerations, if not already aware ---
Main jet size has no effect on air/fuel mixture until after 3/4 throttle, and has most effect at wot where the jet needle is high enough in the needle jet to allow all mixture available from the main jet to pass through the needle jet.
Jet needle taper and position in the needle jet (plus slide cutaway) governs air/fuel mixture from 1/4~3/4 throttle.
The pilot jet governs air fuel mixture from idle~1/4 throttle.
Up to 1/4 throttle position on large Kaw fours produces a surprisingly brisk road speed.
There is a progressive transition as the jet needle takes over from the pilot jet, and another progressive transition when the jet needle thereafter surrenders to the main jet (as the main jet supplies the needle jet absent limitation by the tapered jet needle).
Pods are typically more difficult to tune (than the stock air box) over the entire range of carb operation.
Good Fortune! :)
Thanks, very interesting about transition from needle to main.
96 Yamaha Royal Star
82 Yamaha Virago 920
  • zirafin
  • zirafin's Avatar
25 Mar 2016 06:37 - 25 Mar 2016 06:50
#717256
i have ?
kz550 b2 .tk22
i tace out jet needle ( just 1 to look ) its ok o i need to pot Needle Retaining E Clip lower ??
Last edit: 25 Mar 2016 06:50 by zirafin.
  • loudhvx
  • loudhvx's Avatar
27 Mar 2016 06:52 - 27 Mar 2016 06:54
#717554
Never mind, old thread.
To Zirafin, probably best to keep posts for your bike on your main discussion thread, until the problems are solved. It's easier to help that way.
Last edit: 27 Mar 2016 06:54 by loudhvx.
  • Tesk
  • Tesk's Avatar
25 Apr 2018 22:27
#782385
My mechanic suggested me to buy a 140 jet because I recently bought air pods and my exhaust system is a 4 to 1. My motorcycle is a KZ 750 ltd 1982. Is 140 jet a good decision or nah?
