- Thank you received: 1
Jet needle improves acceleration.
- calvin17d
Can anyone elaborate...............
1976 Kz900 A4
- jms3257
Jim
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
- calvin17d
Collectively across about 5 connections between my patch panel and the kill switch I lost the other volt. There was about .1-.2 volts of drop at all the bullet connectors. I'm sure the ignition wires need replaced. I live in Montana where the riding season is very short so I wired in a relay to supply the voltage needed to the coils. My winter project will involve replacing the circuit.
Now the bike runs much smoother through high rpm's. I did go back to the #4 clip position and put the stock pilot jets in. This is where I get the best performance. I now need to sync the carbs but haven't been able to pull the trigger on the vacuum gauges yet. Thanks to all for the help, and kzrider for providing a great database of useful encounters others have shared.
1976 Kz900 A4
- nads.com
- Thank you received: 20
No possible way to tune it that way,
UP
down
up
down lower
sputter
up
up higher
wait a minute
back down
quit
restart
high
low
repeat.
Dyna takes about 4amps and thats a voltage drop
Relays are a voltage drop. They take as much as one volt when parelelled with the dyna..
I have a question:
What is the voltage of stock coils? What about dyna's?
Not much without at least twelve going in.
- Thank you received: 2098
nads.com wrote: Gotta have full voltage to the coils...
Uncertain whether my understanding (as follows) might help answer the question ---
An ignition coil consumes voltage, and doesn't produce voltage except in the sense of high intensity output through the secondary loop.
Am uncertain about the method or need to measure the high intensity voltage.
I just visually observe for a fat blue spark at the plug tips.
But there's also a Kawasaki "electro-tester" to determine whether the coil is capable of producing at least a 7 mm spark.
Dyna-S requires switched battery voltage in order to function, whereby Dyna-S consumes voltage and doesn't produce voltage.
A good, fully charged, battery, properly serviced and connected, should measure 13+ volts between its terminal posts at idle rpm. And 14~15 volts at 4000 rpm.
Ideally, voltage received at the coil primary terminal should be identical to the measured battery voltage. But there's usually some minimal voltage drop due to loss through the circuit (wiring and connectors and switches) between the battery and coil.
Voltage at the Dyna-S should match the switched battery voltage of the harness wire where the direct single wire connection to the Dyna-S is spliced into the bike's electrical harness. This splice connection is often located near the dual connector where the ignition coils are supplied voltage via a red or red/yellow wire.
- wayno
- spark23ca
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
- Medina
- Thank you received: 8
shimming vs. purchasing that c-clip version
I had a honda, over at that forum it was common to simply take a MACHINED washer (NOT those stamped ones) buy a dozen, mic out four that were identical and literally use them as shims to lift the needle upward.
The sizes slip my mind, but I got a dozen from sears- machined bronze for a couple of bucks. Huge, immediate improvement, to-day on that 550 I had.
Does that not work on the KZ engines/carbs?
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
- DoubleDub
- Visitor
- spudbudy
- Kick it like you mean it
Well I'm not exactly sure but on my bike with vm26 carbs the needle clip position had a big impact I used a afr wideband o2 sensor fot he testing. The test was done @ 5k or approx 65 mph.
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
- nads.com
but won't help the lean condition at wot. This post is too long
to read it all, but if your running a 1015 or 1075 with 26's,
it's way too lean and is running out of gas at around 6 grand.
my 1015 ran weak at the the top with 120 jets. You need a 130
something in there if it's 10 to 1. And the front end will come
up easy. Those are goood wheelie carbs because of the controlled
acceleration but at the end of the day, Way to small to reach
potential reality.
I've got 34's on mine and they open slow and are out of control,
(like all cv carbs) but they open the motor up let here run.
Those 26's are giving the head a sucker face big time.
Don't choke your chicken, even though the carbs are too small,
give the motor more gas and it wil have a new animal alltogether.
Up or down on the needle and you lose it all. The pilot should be
3/4 to 1- 1/4 and thats it. Any more or less and your getting offf base.
going from 120 to 130 is like riding a pony then a race horse.
Now you have me thinking about those kheins again dammit!
Lowering the clip raises the needle, increasing fuel mixture through the needle jet, and thereby enrichens the mixture throughout mid-range of the carb.
Raising the clip lowers the needle, reducing fuel mixture through the needle jet, and thereby leans the mixture throughout mid-range of the carb.
