kz1000j petcock
- kawastrtfgtr
does the reason of it petcock or some thing else?
and i didn't find the fuel tank air vent,where is the fuel tank air vent?
- Thank you received: 2098
- Thank you received: 2237
Petcock could be clogged internally.
Fuel line or filter could be clogged.
Petcock vacuum diaphragm could be cracked or leaking, thereby not opening fully.
Vacuum line could be cracked or leaking.
As Patton pointed out, the vent is in the cap.
Are you sure the problem is fuel-related and not electrical?
- kawastrtfgtr
- MFolks
- Thank you received: 540
I believe the Honda dealers may carry alcohol tolerant fuel lines.
- kawastrtfgtr
- kawastrtfgtr
- kawastrtfgtr
If the advancer is stuck, it should be lubed, or both cleaned and lubed.
kawastrtfgtr wrote: i am thinking about the fuel level in the carburetor; i guess it is not coming to normal level....
If not already done, would perform the clear tube test to determine fuel levels inside the carb float bowls.
- kawastrtfgtr
- camaroguy
