Carb types
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Carb types
03 Mar 2011 10:48
#434658
DoubleDub wrote:
PLUMMEN wrote:
DoubleDub wrote:
If fuel economy is a concern, stick with the 26's. I'm happy with mine and I have a 1075cc kit, but not much for my pipe/cams.
ya wimp! :laugh: i bet you dont even have a billet cam chain tensioner on there,youll have to move to california with craig so you guys can start your own unimpressively stock motorcycle club! :woohoo:
I have the chrome shift fork, though. Does that help?
is it a hardened steel chrome plated shift fork ? :laugh:
  • DoubleDub
  • DoubleDub's Avatar
Re: Carb types
03 Mar 2011 10:49
#434659
It just looked shiny, so I went with it.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Carb types
03 Mar 2011 10:52
#434661
:woohoo:
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
Re: Carb types
03 Mar 2011 12:31
#434698
Hey I'm in California with a stock engine too! (Throwing billet end plugs in asap, so I won't be eligable for membership for very much longer :side:)
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Carb types
03 Mar 2011 12:37
#434699
youll have to talk to craig,hes club founder/chapter president! :laugh:
dont worry im keeping my new ride stock for next 3 years for warranty reasons also! :laugh:
  • mtbspeedfreak
Re: Carb types
03 Mar 2011 12:37
#434700
TeK9iNe wrote:
mtbspeedfreak wrote:
Gotcha, I understood that; I guess I just worded my question the wrong way.
What makes a smooothbore a smoothbore? Other than the bore being smooth- aren't most carbs smooth on the inside to better mix the gas and air not to mention flow better? What is flat about a flatside [other than the side being flat. What's flat? Which side?]?
I saw something called a "26mm Smoothbore" the other day- did the guy have no clue or what? That ad caused me to rack my brain too hard which raised all these questions :)
To put things in a little context, my KZ900 has VM26's on it. People around here get all hot and bothered talking about 29mm smoothies. Would 29mm smoothies be the way to go on a stock 900 with a Kerker? I'd like to get a rack of VM28's, but fuel economy is important to me, so I feel like 28s or 29s would be useless with just a pipe.
Like said, its flat slide, not flat side. Which means the slide inside is rectangular shaped instead of round. This gives better air velocity characteristics.
Smoothbores generally have no cv style butterflys, and have a smoothed transition throughout including the slide base for better air volume transfer, especially at high speed/rpms.
You can use a larger smoothbore on smaller displacement bikes with fewer negative effects than large round slide carbs.
PS. The fuel economy will have nothing to do with the carb size, unless you ride at WOT all the time :laugh: It has to do with your right hand and pilot screw mixtures the most :P
B)
Ahhhhh.. Flat SLIDE!!!! Apparently I'm a little dyslexic.
So I don't have plans to bore my engine out, but I would like to throw a set of a lopey-er cams (without loosing much streetability) in sometime. Next up would be carbs. I'd think the VM28s would be more than adequate for said modifications, but how much more would I pay for 29mm smoothies?
2000 ZRX 1100
  • mtbspeedfreak
Re: Carb types
03 Mar 2011 12:39
#434702
So, a "smoothed transition" in smoothbores (compared to VM26s) is kind of [not really] like porting and polishing your intake, no?
2000 ZRX 1100
  • DoubleDub
Re: Carb types
03 Mar 2011 12:39 - 03 Mar 2011 12:40
#434703
Significant. I just posted a set of 28's from SudmanRacing on Ebay in the Ebay thread. You'll probably be very satisfied with those, from what I've been told.
If you're looking at 29's you'll probably pay close to the same as new Keihin CRS 29's...
dynoman.net/carb/keiCR.html#cr29
Last edit: 03 Mar 2011 12:40 by DoubleDub.
  • DoubleDub
Re: Carb types
03 Mar 2011 12:41
#434704
I'll have to talk to Dynoman - he's got all those junky CB models first. Scroll down to find the KZ model.
  • mtbspeedfreak
Re: Carb types
03 Mar 2011 12:42
#434705
No eBay at work :( I'll check when I get home. I'm also watching a set of 33mm smoothies. If they were jetted properly of course, would they be worthwhile or just be a pain?
2000 ZRX 1100
  • mtbspeedfreak
Re: Carb types
03 Mar 2011 13:32
#434719
Alright, so what's the difference between the Keihin CR29s and the Mikuni [I'm guessing they're Mikuni, don't know for sure though- please interject if I'm wrong!] smoothbore VM29s?
2000 ZRX 1100
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Carb types
03 Mar 2011 14:05
#434737
they still make brand new crs and parts.
29 smooth bores are getting to be like finding origional afbs for a 409 chevy! :laugh:
