- Thank you received: 88
kz900 airbox I.D.
- GregZ
- moneypit
- Thank you received: 35
Maybe look through Ebay and cross referance how they all look to get a better idea of what year, but I say 76
Heres one i found that looks very similar
cgi.ebay.com/ebaymotors/Kawasaki-KZ-LTD-...&hash=item1c19a29a5a
2-76 kz900
St Paul MN
- z1kzonly
- Thank you received: 542
Here is a 76. It has the vent hoses side by side on the filter cover. And it has KHI DGM 30386 S on the lid.
Marty in buffalo
- z1kzonly
Looks like 77 or 78. It has the vent hose on top of each other. Or it only uses one vent.
Marty in buffalo
Here is another pic.
Boy were they hard to take out. I remeber cutting 3 or 4 in half back in the day, just to get them out.
- Thank you received: 2098
Here is a 76. It has the vent hoses side by side on the filter cover. And it has KHI DGM 30386 S on the lid...
As above suggested, note the oem KZ900 side-by-side clips for vent hoses built into rear of filter cover.
The originally pictured air box looks very similar to a KZ900 air box, but appears to have a different arrangement on top of the filter cover (toward the front) for securing the vent hoses.
[Click on image to enlarge view.]
- GregZ
I do see differances between my airbox and other box
I will assume I have one from a 77- 78 I will go swap it out. Gives me another chance to go treasure hunting in the attic. The guy I got it from has 30+ years of kz parts up there.
thanks
gregz
- mtbspeedfreak
- Thank you received: 36
Patton, where are those vent hoses coming from. The carbs, right??? What exactly do they vent?
I have 2 vent hoses that I THINK should be routed up that way. Instead they just kinda hang and end right about where the kick starter is.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Each carb float bowl is vented to outside air.
Left nipple vents #1 and #2 carbs.
Right nipple vents #3 and #4 carbs.
Float bowls are vented for the same reason the fuel tank is vented.
Here are some pics to show attachment nipples and oem hose routing.
Some folks route the two vent hoses to exit underneath the bike, along with the four overflow hoses.
There's a hole in the bike framework through which the vent hoses pass to get underneath the bike seat.
- hal0tw0
- Thank you received: 4
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
I have a related ? My 76 kz900 has vm28 carbs on it with pods. Id like to go back to useing the stock airbox and KN filter that came with the sale of the bike. The carb boots to the airbox are gone. Do I need to us the vm26 boots or ones for the 28 carb setup? Thanks
Am thinking same air box hoses for 26, 28 and 29.
Click > www.z1enterprises.com/detail.aspx?ID=303
- hal0tw0
