Interesting fuel mod on my GPz1100 DFI (long)
  • man-of-war
  • man-of-war's Avatar
Re: Interesting fuel mod on my GPz1100 DFI (long)
16 Jun 2011 19:06
#457645
DFIGPZ
How do I go about resetting the TPS???......... Is this something I could do myself??
Which fuel pump regulator will fit the 1984 GPZ 1100? Can you give me a part number from Accel?
THANKS,
  • man-of-war
16 Jun 2011 19:28
#457648
I also want to adjust the valves there's a ticking coming fron the right side. Could someone direct me to a full how to replace the shims and adjust the valves "LINK".
Or maybe someone has the time to explain how to go about adjusting the valves. THIS IS ALL I HAVE REGARDING THE VALVES. I am assuming this is the wrong book I bought. Click the link below:
www.facebook.com/media/set/?set=a.103702...9715687&l=a44f0b13bc
STEVE
  • cavanaughracing
  • cavanaughracing's Avatar
16 Jun 2011 19:40
#457651
If it has the original parts still.... you have to pull the cams to adjust the valves. It will have shim on bottom setup.
To adjust TPS, the plugs holding the cover of it have to be removed. BE careful. You'll probably need to come up with some new screws to hold the cover back on it. Adjusting is simple.
Engine needs to be up to normal temperature. Loosen the 2 screws that hold the TPS. Turn it to obtain highest stable idle. Have the bike idling about 1100 when you start adjusting the TPS.
It's best if the valves are adjusted properly and the throttle bodies synchronized before you adjust the TPS.
  • DFIGPZ
  • DFIGPZ's Avatar
16 Jun 2011 21:54
#457681
man-of-war wrote: DFIGPZ
THANKS,
Send you F/P regulator to SID POGUE you can contact him at 1-405-677-9397 see post by Larry this is proper way to set TPS. if you suspect valves out of adjustment make sure they are at the proper clearance them make sure you have No air leaks at you intake manifolds then preform throttle body sync then preform TPS adjustment per Larry's post.
1984 750 Turbo
  • man-of-war
19 Jun 2011 07:14
#458150
MFolks
Which fuel pump regulator will fit the 1984 GPZ 1100? Can you give me a part number so I could order it.
THANKS Steve
  • man-of-war
20 Jun 2011 17:29 - 20 Jun 2011 20:34
#458376
Whatever was mentioned above regarding trying to fix the hesitation between 2000 to 3000 RPM on the GPZ 1100 is irrelevent........ The culprit to this problem is the CHECK VALVE that screws into the tank. Click the link below to see the pictures:
Last edit: 20 Jun 2011 20:34 by man-of-war.
  • Polar_Bus
  • Polar_Bus's Avatar Topic Author
21 Jun 2011 06:39
#458486
man-of-war wrote: Whatever was mentioned above regarding trying to fix the hesitation between 2000 to 3000 RPM on the GPZ 1100 is irrelevent........ The culprit to this problem is the CHECK VALVE that screws into the tank. Click the link below to see the pictures:
In my circumstance the culprit was NOT the check valve it was the overall slightly LEAN mapping of the DFI's air fuel ratio. I'm well aware of the issues that can be had with a faulty check valve. In most all cases a debris clogged check valve causes increased fuel pressure, and overly rich running condition.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • man-of-war
22 Jun 2011 09:51
#458695
Now I could get back on track and finish my restoration on this bike. I'm itching to get into the valvs and fix the ticking noise.
