BTW, when the throttle is closed, only 1 of the 3 transition holes are visible. Think this is about right?
Also discovered 1 of the o-rings for my idle mixture screws was torn in half...that must not have helped much.
One other thing I noticed is there is a hole in all four of my passages for the idle mixture screws. They appear to be above where the screw is seated. They are located on the front and would face forward when the carbs are mounted. Are these supposed to be there?
Think I just found something... Is there supposed to be a hole through the center of the pilot jet? I'm guessing it should, but I cannot see one on mine. I was under the impression the passage from the main jet was further up, so the gas came in perpendicular to part of the jet with all the holes, not through the head of the jet (like most jets run).
That must be a very tiny hole...
