Taking carbs apart tonight and super duper nervous
05 Jul 2010 16:51 #380441 by RobQ
I have a KZ550-c LTD and it doesnt start and being a newbie and wanting to learn everything about my bike, i want to clean out the carbs. I have my shp manual here, pictures and diagrams all about my bike all around me and i couldnt be more nervous. Ive taken apart my carb off of my weedeater and my motor scooter but my kz550 has 4 separate carbs and i dont want to mess up. I am going to read threw the shop manual and prolly "cook" the carbs in lemon juice as i once heard that worked great. Any other basic tips anyone with prior carb disassembly knowledge could give me?? If i am cooking the carbs in lemon juice, do i still have to take off the rubber seals and grommits or should i just drop it in the pot and set to carb clean lol jk, what to do what to do?????
05 Jul 2010 17:12 - 05 Jul 2010 17:15 #380445 by bountyhunter
Replied by bountyhunter on topic Taking carbs apart tonight and super duper nervous
Here is what I would advise:
1) remove carbs from bike, do NOT disassemble them (keep the rack together)
2) use a scratch awl or sharp point to number the carb bodies and float bowls.
CLEAN:
Get a 2" paint brush and some naptha or mineral spirits and clen the outsides to get off as much of the gunk as you can. Dont go inside the bores, just outside.
Use a carb cleaner spray and soft brush on the outsides to get them as clean as possible.
Take the bowls off. Hose the bowls as well as you can with carb spray. Soak them if you really want to, I don't do it.
take out the floats marking each with number. Clean needles and floats with carb spray.
Take the tops off the carbs and VERY CAREFULLY remove the slides taking care not to harm the rubbers. Use a sharpie to number the slides. Never soak a carb with a slide still inside it.
Once the tops and bowls are off, you can hold the rack of carbs up and spray like crazy with carb spray or non chlorinated brake cleaner to get the insides clean.
Clean the slides with a soft cloth and acetone, stay away from the rubbers with any solvents.
Reassemble following numbers.
Last edit: 05 Jul 2010 17:15 by bountyhunter.
05 Jul 2010 17:17 #380446 by RobQ
i thought you werent suppost to spray the rubber grommets with carb cleaner being that it would ruin them. So with the tops and bowls off, spraying like crazy inside with carb spray would end up getting the rubbers wet and therefore ruin them wouldnt it???
05 Jul 2010 17:44 #380460 by PLUMMEN
yes carb cleaner will generally play hell on rubber parts.
get yourself one of those aluminum pans youd cook a turkey in and start disassembling,leave the carb bodies racked together.id remove tops/bottems ,floats and slides and and any jets you can remove without destroying.soak the metal parts as much as possible and start scrubbing and cleaning all the little passages in carb bodies .
rubbing alcohal works good on rubber parts in my experiance
05 Jul 2010 17:50 #380464 by RobQ
now that sounds correct and what i wanted to hear. Thank you
05 Jul 2010 17:53 #380466 by PLUMMEN
dont thank me,we're all in this together! :woohoo:
05 Jul 2010 18:19 #380469 by MFolks
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, and adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
05 Jul 2010 18:25 #380471 by RobQ
There you are Mfolks. Good to hear from you again. Thanks for the paragraphs again. ill print it out and try my best.
05 Jul 2010 19:40 #380487 by RobQ
Ok, here is my float bowl with a dried and cracked gasket. where can i get this part and how do i get all the residue off???
05 Jul 2010 21:15 - 05 Jul 2010 21:21 #380515 by bountyhunter
You must remove the slides (pistons) and rubber diaphragms from the carbs first, don't spray them. I actually included that above in my first post. To clean diaphragms: get a VERY soft cotton cloth and soak it in armor all or similar preservative and wipe them gently. The crud comes off and the rubber is preserved. Alcohol or solvents dry the rubber out.
For the other rubber pieces: there's rubber and then there's rubber. Some rubber gets destroyed by fuel and some doesn't. Rubber parts in carbs are fuel and solvent resistant.
Last edit: 05 Jul 2010 21:21 by bountyhunter.
06 Jul 2010 05:13 - 06 Jul 2010 05:24 #380545 by GPz550D1
The TK22 carburetors that are likely on his bike do not have rubber diaphrams. There is a throttle arm on top of each carburetor that lifts the slide (throttle valve) up and down. Relatively easy carburetor to work on.
1981 KZ550-D1
Last edit: 06 Jul 2010 05:24 by GPz550D1.
06 Jul 2010 12:06 #380597 by TexasKZ
MFolks wrote:
Carb Cleaning 101
By M. Shively
Geez MFolks,
do you have a macro key set up to instantly post this? If not, you may be in danger of carpel tunnel syndrome. ;)
