Carb Shooting Flames! Wicked!
- KZJAT
Re: Carb Shooting Flames! Wicked!
09 May 2010 21:55
I actually have the tank off(rusty) and have an improvised setup with an funnel type holder w/ lid and some clear hose. There is a fuel filter in between the clear and original black fuel hose that's attached to the carbs. You could be right, I'll check tomorrow. Thanks.
- loudhvx
10 May 2010 10:31
Yeah if you're not using the tank, then get a piece of copper tubing or somthing to connect the clear hose to the black rubber hose. Also, when you put everything back together, only use black fuel line. The clear stuff or blue urethane, or vinyl will not last long at all.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
