26 mm Smoothbores ?
- Bad Dad
I spent all day cleaning and polishing the carb bores, and I'm thinking of Gun-Koteing the bodies a dark grey or black (fake CR's). I used a Dremel, with an abrasive "buffer" pad, then "Flitz" polishing compound with a felt drum. I had no intension of removing material to increase the bore size, but the polishing should slightly increase the CFM they will flow.
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Bad Dad
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- roy-b-boy-b
- Thank you received: 103
- Mcdroid
- Gone Kwackers
- Thank you received: 319
That looks good. Roy
I'm with Roy...well, not literally :huh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Old Man Rock
- Thank you received: 225
Even though not intentionally as you mentioned, to buff to that shine you would have a slight amount of material no doubt thus increased CFM...
It will be interesting to see what jet changes you'll need to accomplish... Of course, also going to depend on other factors such as if you're changing to pods, exhaust, head P&P etc....
Definitely let us know the results...
How long did this take you on the polishing the bores?
Damn those are purdy!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Bad Dad
Unless you are running the quarter mile with a stop watch you will never know the difference. If you really want better throttle responce you'll have to port and polish the head too. But, OMR is right they look great.
Thanks everyone... I think this will be it for now, then next winter tear her down for a rebuild -- at that time, I will attempt a mild port and polish job.
OMR, I believe I spend about an hour on each carb, half of that time "hand polishing" the bore (the other 1/2 hour w/the Dremel). Oh, and I am adding pods & exhaust when I mount these, so I'll keep ya posted!
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- larrycavan
- Visitor
- Bad Dad
s765.photobucket.com/albums/xx298/Bad_Da...current=DSC01166.jpg
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Bad Dad
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Bad Dad
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
