new guy, need some info on air cleaner box removal
- the wolf is watching
1980 kz550 a1
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- hmeric7
1977 KZ 1000 LTD
- Thank you received: 2829
Thread
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- spudbudy
- Kick it like you mean it
- Thank you received: 1
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
- cobura
- forever 2 wheels
Don't remove it unless your going to do the airbox mod I did and put it back on. Believe me it will flow fantasic without the constant rejetting problem of pods.
Woah really? Is there a thread on this already? Care to elaborate? I thought the reason you have to rejet your carbs with pods is because you are getting more airflow, but this mod, isn't it doing the same thing? Are you sure you dont have to change jet sizes? Or maybe your mod actually doesn't improve airflow at all? No insult, I'm just very interested in this idea.
1979 KZ650B3
- Thank you received: 2098
kzrider.com/index.php?option=com_content...view&id=27&Itemid=11
- Bluemeanie
- Thank you received: 14
- JMKZHI
- Thank you received: 48
Uh, why are you removing the airbox?... I have already decided that if i have to take it off again, ...
