- Thank you received: 337
Hesitation: But ONLY at WOT Gear Shift
- bountyhunter
If I crank it up hard in a low gear with WOT, then let off the throttle to shift gears at maybe 5000 - 6000RPM, then when I crank the throttle back wide open there is a definite hesitation and then the power hits on hard.
The fuel levels are right, there is never any hesitation when I hammer the throttle under any other condition, it's just when I am winding it up, let off fully to shift, and snap the throttle back open.
Otherwise it pulls very strong at just about any condition where I snap the htrottle open.
The only thing not stock is I have put in different carb vacuum pistons (slides) because the rubbers on the originals were shot. The new ones are off a newer year and slightly different than stock, but I am using the stock needles (which are adjustable) set to the same height below the flat surface of the piston.
- MFolks
- Thank you received: 540
Sparkplugs and wires good?
- bountyhunter
- TeK9iNe
- What did you do!?!
- Thank you received: 28
In your case, it might be something with the slides, like the cutaway, or sticking or something...
My advise is don't close the throttle.
You only need to blip the throttle back some to shift up without touching the clutch.
You certainly don't have to close the throttle, then slam it back open.
Add some fuel to your pilot circuit via the mixture screws, and see if that helps.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- guitargeek
- Thank you received: 50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- bountyhunter
Hmm, good ideas. The pilots are pretty much dead on, I actually have tried different jets and settings. I am using the stock 45's right now, 47.5 ran a shade rich.I've seen that happen on more than one bike.
- bountyhunter
Bountyhunter, just a shot in the dark, But, c/v carb pistons have a vacumn control orifice located in the vicinity of needle jet hole. It's diameter controls slide rate & speed. (that's why some jet kits use different springs, & require drilling/restricting .) In some cases, diaphrams can be swapped. & may be an option. luck G
I was suspecting there might be a subtle difference between the slides. I don't want to try swapping the diaphragms because I am sure I would tear them. Screwing with 30 year old rubber is not for me.....
- bountyhunter
I have actually played around with needle height, my needles have five slots and I think I am on the one that runs best.Raise your needles.
- guitargeek
- bountyhunter
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
I hate them. They are THE most persnickity carbs I've ever messed with. Mostly because of the bizzare single throttle cable that splits into two, one for each carb. To synch them, your supposed to slowly turn the throttle, watching for each slide to start moving at the same time, then adjust the cables until they do start opening at the same exact time.
I've done that, but I still have similar symptoms as you do. And I think the reason for that is the diaphram springs might be slightly different from each other, so they're probably not really synched at all.
Do you have any kind of vacuum ports you can hook some guages up to them to see what's really happening?
