Corrected Spark Plug "BASE" Reading
- Old Man Rock
Re: Corrected Spark Plug "BASE" Reading
05 Feb 2010 04:27 - 05 Feb 2010 04:35
@ Mark: Nothing over kill, just a tad larger then stock 900 size. KZ1000 sized SS valves on intake & exhaust. New OEM seals, APE guides, APE springs. Sorry, forget the actual dimension sizes if you need, I can get for you...
Nads: As for the wheelie, please keep in mind I have a 15/37 tooth combo on the sprockets. I also have a lighter front & rear with the ZX636 set up. The ZX also uses dual 17" tires (120mm front/180mm rear) versus the skinny KZ900 18/19 sizes.
I also use Michelin Road Pilot 2 series tires and they grip extremely well...
With that big ass rear, there's a whole lot of tire surface griping the asphalt so spinning is not an issue what so ever... Not that I would or will try to (ruin a tire or end up on you-tube dumb-ass video's :blink: ), you'd really have to twist the throttle pretty hard to get her to break grip for spin.... Could it be done, surely but not by me...
In running my setup on gearing commander here's the results if you're interested....
NOTE: The calculated versus real time came out pretty close, not spot on mind you to other obvious variables but close...
Example:
In 5th gear, difference in ~ 20 between MPH and RPM.
@ 65mph = 4500rpm on my tach in 5th gear...
@ 85mph = 6500rpm on my tach in 5th gear...
Downshift to 4th gear.... :evil:
In 4th gear, difference in ~ 15 between MPH and RPM.
@ 65mph = 5000rpm on my tach in 4th gear...
@ 85mph = 7000rpm on my tach in 4th gear...
Now due to my build and cam selection, I chose to loose top end speeds for low to mid range gains... See the way I look at it, she'll max out at ~ 120mph... More than fast enough for me...
Digital ODM retains maximum speed & RPM recordings, 106mph is it at this point. If that's no fast enough, well don't know what to tell you for on a raw naked KZ (no fairings) you're being pulled back with some serious force...
Now the real fun for me (Woody) is getting to that 100mph range for she get's there really damn fast! The acceleration force is insane, blows me away... So far, everyone I've ridden with has tried to see what the old girl has for balls and she truly surprises them... :evil: I can't even count how many times after the event, they'll walk up grinning and say "Ok, what the hell did you do to her again"....
OMR
Example:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Feb 2010 04:35 by Old Man Rock.
- larrycavan
05 Feb 2010 05:04
Why would anyone want to idle one of these motors 500RPM below standard idle spec? Most especially with aftermarket cams & stiffer valve springs.
That slows done the oil pump causing less oil flow available to the top end of the motor.
When doing a really fine tuned carb synch, it's common to drop the idle down to 500 RPM for that process but there is no mechanical benefit in leaving it there.
- Kawickrice
05 Feb 2010 05:44
larrycavan wrote:
Great advise I usually do my idle by ear and sometimes get her pretty low as long as its smooth. I have never thought about the oil thing so I will keep that in mind from now on
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- nads.com
05 Feb 2010 12:56
larrycavan wrote:
Just thought if it idled at 12 or 13 it would definetly not idle that low or very close to that low. I would never run it like that, mines at 8 or 9 all the time. I realize it's the lobe centers that he's set the cams at that's the reason for the higher idle. That's a good question, though for another person who actually has a 500rpm setting.Why would anyone want to idle one of these motors 500RPM below standard idle spec? Most especially with aftermarket cams & stiffer valve springs.
- larrycavan
05 Feb 2010 14:40
mark1122 wrote:
Mark,
They're 36 /30 with 88% throats.
OMR, what size vales did Larry install?
Mark,
- larrycavan
05 Feb 2010 14:45
nads.com wrote:
I don't know what you have for cams or valve size but a 111 lobe center call is often an indication that things get close at TDC overlap. So if you have a lot of TDC overlap and / or oversize valves, keep that in mind.
I meant valve to piston clearance there. If your bike has stock gearing and lifted off in 3rd, it has alot of power and I have to say I'd change my 111 lc on the intake to 105 just to see what power mine had there. If it has lower gears, I guess I can't compare with mine but I think it would come off the ground in third as well. I'm just trying to figure out if More power is available with lobe center settings like yours due to the cylinder filling, cranking compression, exhaust scavenging. I know the carbs you run are helping alot for torque and that magic port work from Cav racing. All that said I'm ready with the degree wheel for this summer. One last question, did you mill the head or deck?
- nads.com
05 Feb 2010 14:55
larrycavan wrote:
You mention things and I assume you mean valve to valve contaact. 111 is one one lc. Since overlap involves two centers and my ex. center is advanced I believe the valve to valve clearance is greater in comparison with 105/105. Thanks for the heads up though, if my estimation is incorrect I'd certainly respect correction from anyone willing to inform me it's otherwise.nads.com wrote:I meant valve to piston clearance there. If your bike has stock gearing and lifted off in 3rd, it has alot of power and I have to say I'd change my 111 lc on the intake to 105 just to see what power mine had there. If it has lower gears, I guess I can't compare with mine but I think it would come off the ground in third as well. I'm just trying to figure out if More power is available with lobe center settings like yours due to the cylinder filling, cranking compression, exhaust scavenging. I know the carbs you run are helping alot for torque and that magic port work from Cav racing. All that said I'm ready with the degree wheel for this summer. One last question, did you mill the head or deck?
- Old Man Rock
05 Feb 2010 14:57
Someone correct me if I'm wrong here but from other postings here in KZR land, a good running stock 900/1000 will wheelie in 3rd when wraped hard enough so I must be missing something in this conversation...
Hell, if you want to wheelie all day long, through a 41 tooth rear sprocket on her....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
05 Feb 2010 16:17 - 05 Feb 2010 16:18
nads.com wrote:
Correct.
What cams are you running?
With mild street cams, there's usualy room to play with centers but others have a comfort zone that gets narrow.
Andrews 3x in particular had a lot of overlap lift .173" but is still a street cam. The 8x has roughly 1mm less lift .132" at TDC than the 3x. Both grinds called for 106 lobe centers.
Believe me when I tell you that extra .041" is a world of difference in what you can get away with sometimes for cam timing, depending on the valves that are in the motor. You can get a narrow range of a few degrees where it can get real tight :woohoo:
larrycavan wrote:You mention things and I assume you mean valve to valve contaact. 111 is one one lc. Since overlap involves two centers and my ex. center is advanced I believe the valve to valve clearance is greater in comparison with 105/105. Thanks for the heads up though, if my estimation is incorrect I'd certainly respect correction from anyone willing to inform me it's otherwise.nads.com wrote:I meant valve to piston clearance there. If your bike has stock gearing and lifted off in 3rd, it has alot of power and I have to say I'd change my 111 lc on the intake to 105 just to see what power mine had there. If it has lower gears, I guess I can't compare with mine but I think it would come off the ground in third as well. I'm just trying to figure out if More power is available with lobe center settings like yours due to the cylinder filling, cranking compression, exhaust scavenging. I know the carbs you run are helping alot for torque and that magic port work from Cav racing. All that said I'm ready with the degree wheel for this summer. One last question, did you mill the head or deck?
Correct.
Last edit: 05 Feb 2010 16:18 by larrycavan.
- nads.com
05 Feb 2010 17:11 - 05 Feb 2010 17:31
Old Man Rock wrote:
My bike has .407 cams 280deg@.020 and a 1015kit. If my bike could, it would be at 85mph but it doesn't even come close. I'd have to say: "It's not easy." "Only a Caveman could do it" So all u Cavemen out there sit down, take off the jacket, smile and show us that bicep flex again. Attaboy!
I'd like to hear from anyone who could wheelie a stock 900 with a kz head in third without standing on the back pegs or pulling up hard. That would be some serious power to the ground, back to the drawing board for the rest of us.Someone correct me if I'm wrong here but from other postings here in KZR land, a good running stock 900/1000 will wheelie in 3rd when wraped hard enough so I must be missing something in this conversation...
Last edit: 05 Feb 2010 17:31 by nads.com.
- nads.com
05 Feb 2010 17:25
larrycavan wrote:
Causing future damage from unkown v to v clearance is scratched off the list after that info, thanks Larry. That probably would have been my next mistake playing with those cams not realizing how close things were getting in there. I may never have known what happened even after a round two event.nads.com wrote:larrycavan wrote:You mention things and I assume you mean valve to valve contaact. 111 is one one lc. Since overlap involves two centers and my ex. center is advanced I believe the valve to valve clearance is greater in comparison with 105/105. Thanks for the heads up though, if my estimation is incorrect I'd certainly respect correction from anyone willing to inform me it's otherwise.nads.com wrote:I meant valve to piston clearance there. If your bike has stock gearing and lifted off in 3rd, it has alot of power and I have to say I'd change my 111 lc on the intake to 105 just to see what power mine had there. If it has lower gears, I guess I can't compare with mine but I think it would come off the ground in third as well. I'm just trying to figure out if More power is available with lobe center settings like yours due to the cylinder filling, cranking compression, exhaust scavenging. I know the carbs you run are helping alot for torque and that magic port work from Cav racing. All that said I'm ready with the degree wheel for this summer. One last question, did you mill the head or deck?
Correct.
- Old Man Rock
05 Feb 2010 20:08
So all these postings I've reviewed over the course of the last 3 years regarding "wheelies" was BS then?... :ohmy:
Wow, somewhat hard to believe that this could not occur in a stock 900/1000 but ok....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
