- Thank you received: 1
1980 KZ 1300 Spitting problem
- unomike
- Biker for 40 years.
1.General tune up including new plugs
2.oil/filter change
3.Carbs stripped, sonic cleaned and a Stage One kit installed.
4.Bad Stator replaced – charges at 13.8 volts.
5.Ignition wiring/coils inspected and tested – within specs.
Note: Bike came with Accel coils and pods installed.
Hopefully this is something easily solved and fixed. …. Any Suggestions?
Own: 1980 Kaw KZ1300,Stage 1 kit,K&N pods
1972 Harley Davidson XHL Sportster, 1972 Suzuki T500, 1974 Hodaka 125 Dirt Squirt, 1980 Honda 250 VTR, 1983 Yamaha 750 seca and a 1974 yamaha GT80 for my son.
Bristol, Tennessee. USA
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- unomike
- nads.com
- Thank you received: 20
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- unomike
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Sorry to hear man, I know how that feels.Sorry guys, I ve been out with a killer toothache and not feeling up to snuff.
Which it doesn't...Battery being bad... Not sure if this has anything to do with the spitting
Time to go to another mechanic Sorry if he's a friend. :dry:mechanic seems to think the bike's electrical system was taxed trying to charge a dying battery and not supplying enough juice to operate the ignition system.
Nope... If your stator/rectifier/regulator was dropping 13.8 into the battery, then thats what your coils were getting... unless the wiring is toast. Battery just acts like a big capacitor once bike is running.In other words, a weak spark from a degraded battery.
I'm not sure what you mean by spitting out the exhaust? Do you mean that its making a loud clacking noise out the exhaust flange while running? Or its spitting out the end of the exhaust pipe, like fuel?
While running, are all the cylinders firing? Check by tapping (VERY QUICKLY) at the 2nd bend in the exhausts for each cylinder. They will be very hot, just shortly after running if all is at least OK. Water will sizzle off each one, if thier at least reaching proper operating temp.
Spitting may or may not have something to do with the valves... the gaps should be checked regardless, as this is considered part of the regular maintenence of that bike.
Hope this turns out helpful.
Cheers, good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- unomike
OK, to describe the "spitting" through the exhaust. .. I think the sound is like a valve closing a little late on the compression stroke. I cannot describe the actual sound other than a spit at idle. When the engine is rev'ed up it goes away, or at least masked by the increased exhaust noise. Anyways, I'll know more about it in the morning.
- TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- unomike
