cv34 not fueling on #2
- Eldiablo
- 1978 kz650 with 81 750 motor
i have the cv34's that WG rebuilt. but the #2 doesnt seam to be giving out any fuel. its getting spark, the cylinder has good comp, but the plug looks like its just a little wet but thats it.
ok just took it for a ride. once you get past half throttle the thing takes of line a bat out of hell.
so it has to do with the idle jetting i am guessing
1978 kz650 with 81kz750 motor, dyna coils/pickup, 4/1 header, d&d pipe, pods, gsxr brake controls, airtech clipons, r1 taillight, and cafed out
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Eldiablo
like i edited above. once you get to 1/2 throttle it takes off like a jet.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
When starting the cold engine with choke applied, is there combustion in #2 cylinder?
Do these carbs have a separate enrichener circuit or a true butterfly style choke?
Good Luck!
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
1) remove the tank
2) Remove the drain plug from the bad carb.
3) remove the pilot needle from the same carb.
4) fill a sirring with some gas
5)seal sirring to pilot screw opening with an o ring or small hose.
6) In 2cc increments squirt into the screw opening
7) Repeat about 3-4 times.
This should clear any obstruction, and flow it out the drain hole.
Reinstall pilot screw and open to the correct amount of turns.
This trick will work if the hole was clogged after the rebuild. It most likely not work if the rebuild was not done properly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mtkawboy
- Thank you received: 16
- keith1
See if WG will do good on his repair.
ahhhhhhhhhh....nevermind....:laugh:
- Eldiablo
- JR
- Thank you received: 449
Look into that end of the carb which connects to the motor.
Open the throttle flap and look up. First in is a tiny hole which is from the air mix screw directly above. Easy to spot. Just beyond the throttle flap and further in from the air mix hole are the transition holes. 3 tiny holes. I use a very fine bent wire to poke them clean. The smallest piece of dirt will block them and while the bike will start ok with the pilots clean it will run like crap in the lower rpm range and only run proper at >3000rpm.
I spent an entire summer tearing my hair out before I found these transition holes. Could be the source of your problem ?
Just reading your post again and wondering if you are thinking the pilot jet screw is on the outside top of the carb closest to the engine. Thats the air mix screw and it should be turned out 2 turns from lightly seated. The pilot jet I was talking about is only accessible from inside the carb
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Check the others to see how many turns out they are, and they should all be close to the same. Put your #2 on a setting similar/average of the other carbs.
Out = more fuel mixture/In = less.
...ride on
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
