BS34 Carb pilot jet plug
22 Oct 2009 18:52 #329035 by spdrcr9
BS34 Carb pilot jet plug was created by spdrcr9
Hello all, newbie to this forum, but i had something that I wanted to everyone know.
The plug under the idle jet is a must, just found out the hard way. Bought the bike about four years ago, has never run right, i've changed alot of things on this bike before i found out tonight that the plugs were supposed to be there.
81 KZ 1000
73 CB 500 Four
New Braunfels, TX
02 Nov 2009 13:53 - 02 Nov 2009 14:08 #331132 by 82kz1000P
Replied by 82kz1000P on topic BS34 Carb pilot jet plug
I just cleaned my carbs and removed the pilot jet plugs (and threw them away); it runs great below 4,000 rpm, but above 4,000 rpm when I give it more than 1/2 throttle, it breaks-up/misfires; I put in new spark plugs and the tips are white, so I'm thinking its lean due to air leaking via the intake boots (I ordered new ones). I would think if I had a problem due to removing the the pilot jet's plugs, it would show up at start-up, idle, below 4,000 rpm, etc., not at high rpm. Why do you say the pilot jet plugs need to be there? How would the gasoline get thru with them there? Do you think that could be my problem above 4000 rpm? Thanks for this post.
Last edit: 02 Nov 2009 14:08 by 82kz1000P.
02 Nov 2009 17:29 #331185 by timebomb33
Replied by timebomb33 on topic BS34 Carb pilot jet plug
replace your rubber plugs it sounds to me like all your problems started right after you removed them the two things may be related, maybe. if it was your intake boots it would be lean at idle and and not return to idle very easily. rpm's would hang up.also the warmer the bike gets the worse the problem would be.
I THINK MY POWERBAND BROKE
02 Nov 2009 17:40 #331190 by spdrcr9
Replied by spdrcr9 on topic BS34 Carb pilot jet plug
That's the same as my bike was doing. When i bought the bike the plugs were not there, I made plugs from a lead sheet and it runs oh so much better. Inside the hole whre the main jet goes there is a hole that feeds the pilot jet, that is how gas gets to the pilot jet, with out the plugs the gas gets sucked through that hole which is above the main jet & floods the engine on anything above half throttle. Hope this helps, just thought i would post with my personal experience of the same situation.
81 KZ 1000
73 CB 500 Four
New Braunfels, TX
02 Nov 2009 17:55 #331196 by roy-b-boy-b
Replied by roy-b-boy-b on topic BS34 Carb pilot jet plug
Dern, I've been running mine since July with no plugs.
I hope i can get some from Jeff. Roy
02 Nov 2009 18:02 #331197 by spdrcr9
I've read on here some where that some of these carbs can run fine with out them, but the ones i have will not, so if the bike is running good then i probably might not worry about it. My bike would not rev & the plugs were always very black.
81 KZ 1000
73 CB 500 Four
New Braunfels, TX
02 Nov 2009 18:38 #331210 by roy-b-boy-b
I'm going to pull the head this winter and i will go through the carbs also. I'm running 40/140 jets. Roy
03 Nov 2009 06:57 #331263 by morningwood
Replied by morningwood on topic BS34 Carb pilot jet plug
not trying to be a smart ass. but, why would someone tear apart their carbs and then discard internal parts???
03 Nov 2009 07:21 #331267 by OnkelB
Replied by OnkelB on topic BS34 Carb pilot jet plug
Roy, I mailed Jeff about these plugs recently - they do carry them, temporarily out of stock but they should be getting some soon.
Here's a link.
77 KZ 650 B1, 82 GPz 1100 B2.
03 Nov 2009 08:23 - 03 Nov 2009 08:29 #331275 by 82kz1000P
because I'm an idiot. The bike runs great at lower RPM and starts instantly; I can't even touch the starter quick enough for it not to start, even when it's 35 F outside (and no cold stumble...wish my harley ran like that), so I didn't even think high RPM issues could be due to the pilot plugs (which I though I read on-line should be removed...didn't see anything about putting them back...thought they were EPA mandates...). I put new carb body screws in and after about a week, just threw away the plugs along with the old screws. It was until I read spdrcr9's post that I even thought about them again (thanks a bunch spdrcr9!). However, I ordered 4 new pilot jet plugs and their o-rings from Ron Ayers ($35 delivered), so at least I'm able to get new ones.
Last edit: 03 Nov 2009 08:29 by 82kz1000P.
03 Nov 2009 08:49 - 03 Nov 2009 08:53 #331278 by morningwood
again not trying to be a smart ass. every part is a cost to the manufacture. so if the part is present, then there is a very good reason for it being there. just my two cents for what it's worth.
oh, almost forgot to point out. the o ring end of the plug goes in first. if you install the plugs wrong you can NOT remove them easily. to do that will be a major PITA.
Last edit: 03 Nov 2009 08:53 by morningwood.
03 Nov 2009 09:33 #331285 by 82kz1000P
Thanks. I would agree in general; it's not the case here, but I would think there are some governmental mandated items that the manufacture would just as soon leave out; the pilot screw plug comes to mind. Re: putting the plugs back in, can't the plugs only fit in one way?
