- Thank you received: 14
Float adjustment question...
- Bluemeanie
- chance
- Life long biker/
- Thank you received: 2098
In this example, am thinking "main" system (not "float" system") whereby higher level on bleeder tube allows more fuel being sucked from needle jet opening as incoming air rushes past enroute to intake port.
Good Luck!
- Bluemeanie
- TeK9iNe
- What did you do!?!
- Thank you received: 28
It all works based on volume. Not fuel height. Although that is the best way to get an acurate reading of the fuel volume in the bowl, becuase of float-stop deficencies.
The free air that reaches the bowl when the engine creates vacuum becomes higher pressure than the air in the carburetor venturi. Thus it applies a pulse of pressure on the volume of the fuel in the bowl. If the fuel volume is to big (high), the pressure pulse pushes more cfm's (volume) fuel into the venuri. A rich condition. Consequently the opposite when the fuel is too little (low). A lean condition.
Fuel volumes are super important!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- savedrider
- 1975 Z1-B 900
Seems you would want to do it on the bench so you can make adjustments as needed right?
Guess I'm answering my own question now, but I was curious.
Get right or get left! <*{{{><
Hey Bluemeanie, when you used this tool did you do it with the rack on the bike or did you do it on the bench?
TIP --- When removing and replacing the float bowls between float tang adjustments and observing fuel level inside the clear tube, only one float bowl screw is needed. Saves time and effort.
Good Luck!
- HerrDeacon
I know this! :laugh:
Cheers!
Great explanation TeK9iNe, thanks for posting. I always wondered about it as well.
- Bluemeanie
Some guys have made a board with old carb holders then clamped it in a vice. I removed carbs and then gently clamped them in a vice making sure they were perfectly level. Used a Gator aid bottle (wide mouth) to catch gas when removing drain screw or tool. After adjusting all four carbs I simply poured gas (half a bottle) back in tank.
It's the normal air pressure pushing down against the surface of the liquid that pushes the liquid up through the straw toward the vacuum being created by suction at the other end.
Sucking harder creates more vacuum (less air pressure at the sucked end) whereby more liquid is pushed up through the straw.
Instead of sucking on the straw, air blown fast enough across end of the straw also creates a vacuum, whereby liquid is pushed up through the straw. Same principle involved.
Another way to look at movement of fuel from floatbowl to carb bore is from the standpoint of "venturi effect" as explained in the Sudco manual.
It's like the "suction" created by fast moving air across end of the straw.
The fuel inside the float bowl is vented to normal outside air pressure, and is supposed to stay that way. Just like the liquid refreshment in the glass.
When the engine isn't running, the same normal outside air pressure exists inside the carb bore, there's no venturi effect --- Like when not sucking on the straw.
When the engine is running, air movement through the carb bore creates a lower than normal air pressure (i.e., venturi effect), which "vacuum" draws fuel mixture up from the floatbowl through a brass tube that ends with a needle jet at bottom of the carb bore (through which needle jet the tapered jet needle moves up and down, whereby volume of fuel is metered by throttle position). In other words, normal air pressure constantly being exerted on the fuel inside the float bowl "pushes" fuel up through the main jet, brass tube, and needle jet. Like sucking on the straw.
Fuel level inside the float bowl determines how much fuel is drawn up through the brass tube (aka pickup tube or bleeder tube) via the venturi effect and thereby available at the needle jet for being drawn through the intake ports and valves into the combustion chamber. Too high causes too rich. Too low causes too lean.
Good Luck!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- float level gauge
- float gauge
- carburetor float guage
- Kawasaki float level gauge
and nothing.
I've been 'hit-or-missing'
my float adjustments and I really like that 'runs smoother with better throttle response' !! Sounds great.
Does anyone know where to find that item on eBay, or know of another source? thanks.
The Kawasaki kz1000 '77-'78 service manual calls out the 'special tool' part #57001-208 that looks very much like it. Betcha that costs megabucks from Kaw though!
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- Bluemeanie
