Carburetor Diaphragm Repair
  • otakar
  • otakar's Avatar
Re: Carburetor Diaphragm Repair
12 Aug 2009 05:24
#313321
bountyhunter wrote:
otakar wrote:
bountyhunter wrote:
mkeating wrote:
How much would a couple of tiny holes affect the performance.
More than you would believe. It keeps the slides from rising at small throttle openings giving poor throttle response.
Actually the slides do not start opening until the throttle is about a quarter open so a tiny pinhole will not do much damage.
I guess it depends on what we call a small hole. Mine each had a couple of tiny slits maybe 1/4" long and were giving really bad throttle response. I had to compensate with larger pilot jets and moving the needle to get it rideable. Once I plugged the slits, it ran normal again. Amazing how long I screwed with the carbs before I found those little slits in the "lace curtains" near the rim of the rubbers.
I am talking about a "pinhole" or two. A slit or a tear is a different matter altogether.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mkeating
  • mkeating's Avatar Topic Author
12 Aug 2009 05:36
#313326
Just to clarify, I have three small holes, roughly about 2mm wide on each of the diaphragms.
  • bountyhunter
  • bountyhunter's Avatar
12 Aug 2009 14:16
#313418
IMHO, that will screw up performance.
  • tygoebel
  • tygoebel's Avatar
15 Aug 2009 17:56
#314185
I also have 1981 kz 440
I used Gorilla Glue on my carb diaphrams.
Use a cotton swab (Q tip) to apply on both sides of hole.
Gorilla glue tends to puff up in about 5 min or so, if this happens just push the puff down with your finger. Do not get any water or liquid on the glue until it is dry, this make the puffing worse. Also use as little glue as possible.
Any way this is working for me.
Good luck
  • JR
  • JR's Avatar
15 Aug 2009 18:15
#314215
mkeating wrote:
Does anyone know where you can buy the grease paper that the adhesive will not stick so that you can plug the hole while you spray it??
Greaseproof paper
Look in your local supermarket in the baking supplies aisle.
It may also be called baking sheet. Comes in a roll in a cardboard box. Made by Glad :)
  • Jbosh
  • Jbosh's Avatar
  • 1982 Kz440 ltd D4
28 Jun 2016 05:23
#733116
mkeating and the rest of you, thanks a bunch for getting this conversation going! At what point should you just replace your diaphragm skirt? After 3 holes? If they are more than 2mm in dia? I wish o knew why my right side was in such bad shape with the left just perfect. I'm off for some gorilla glue and PD in the meantime. Thanks a ton!
As long as I get to learn something, I'm happy!
  • Nessism
  • Nessism's Avatar
28 Jun 2016 07:19
#733127
Jbosh wrote: mkeating and the rest of you, thanks a bunch for getting this conversation going! At what point should you just replace your diaphragm skirt? After 3 holes? If they are more than 2mm in dia? I wish o knew why my right side was in such bad shape with the left just perfect. I'm off for some gorilla glue and PD in the meantime. Thanks a ton!
I'd get a new slide or replace the diaphragm. There are aftermarket diaphragms available. Search out the source with google.
The following user(s) said Thank You: Jbosh
  • martin_csr
  • martin_csr's Avatar
28 Jun 2016 12:32 - 29 Jun 2016 05:15
#733165
There is a seller on eebbaayy who sells the diaphragms & has a good how-to w pics. I've seen them for the 440.
JBM Industries is another place.
eebbaayy search = kz440 diaphragm rubber
Last edit: 29 Jun 2016 05:15 by martin_csr.
  • baldtires
  • baldtires's Avatar
28 Jun 2016 21:20
#733216
