Totally rediculous idea...
- N0NB
- Blue handles better
Re: Totally rediculous idea...
16 Mar 2006 06:52
Based on that description, George, I've been spoiled by the one-piece 650 airbox.
- Nate >>
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- The Fish
16 Mar 2006 07:57
On my Dunstall CB 750, I modified the stock air box to house 4 pod filters. I then opened up the bottom/front of the air box to have a sort of ram air effect. It works fine, but I didnt find that it made any noticable power improvements and I dont have a Dyno.
Fish
Fish
- nfswift
16 Mar 2006 22:36
I'm kind of getting less keen about the RAM idea because of water seepage and the problems that could cause being mounted RIGHT on the front of the bike.
That airbox hose mod with the pool tubing is EXACTLY what I need to do though, if this mystery airbox will even fit into my frame... hmm, may need to do some fabricating.
All the same, I may shelve this manifold/RAM idea for a later date.
- 77KZ650
16 Mar 2006 22:43
I think the 1-4 intake could work, its just like a 4-1 exhaust reversed, if the tubes/pipes(pvc) were the right size, and the "collector" was large enough it should be fine flow wise.
sort of like this crude drawing
Post edited by: 77KZ650, at: 2006/03/17 02:06
07 MDP Rookie of the Year
- Tarmac
17 Mar 2006 08:15
RAM air isn't really worth doing at subsonic speeds. The increased drag would probably outweigh any performance gains.
- RomSpaceKnight
17 Mar 2006 14:10
3% HP gain just from routing air from the front of the bike to the airbox. Sounds like a deal to me. If you make 160+ hp from a fairly modern motor, I would think a 3% increase in HP would cost you a whole lot more money in engine work than a RAM air would.
- N0NB
17 Mar 2006 14:33
RomSpaceKnight wrote:
I'm going to go out on a limb here, but I'm thinking Kevin Cameron was refering to air pressure gain and not HP. Also, 3% was at 160-170 MPH! 80 MPH yields less than 1%. And of that, engineering can only expect about 75% efficiency.
A turbo charger would be more productive and useful at street speeds, IMHO.
- Nate >>
- Nate >>
Nate
- nfswift
17 Mar 2006 17:44
- Nate >>[/quote]
Well certainly.
That involves a disparity in price of easily 1,000 dollars though
- Nate >>[/quote]
Well certainly.
- the_kz_kid
29 Mar 2006 20:33
I realize I'm a little late for this thread, but I've had a little experience analyzing an intake. I did some CFD analysis on 1-4 intakes like that described above when I was in college, and in all cases the outer cylinders (1&4) were starved of air.
An airbox better regulates the pressure so that all cylinders get the same amount of air, so that its more like the carbs are sucking fresh unaffected air.
