Black spark plugs
- jeffff
- Thank you received: 2098
I have a 1978 KZ1000 ltd with 15,000 mi on it,when i bought it the carbs were all gummed up,i'm a pretty good wrench and i did every thing right in my book but am haveing trouble with the plugs black with soot after only about 3 miles.Here is what i have; stock carbs with stock pipes that ahave no baffles(i like noise)120 main jets, 15 pilot jets, stock needles on the middle notch,all carbs cleaned, bead blasted exteriors, floats set to specs,all passages seem clean and clear!! Did the add a relay to the coil system for full power to the coils, new NGK resistor type plug wire ends,compression test 95-105lbs accross the board. # 1,2&4 are sooting and #3 is perfect, all settings on the carbs seem equal. What the heck am i doing wrong???If any one has an idea i'll be glad to listen. THANKS JEFF
Thanks for all the good info , and could use a little more.
floats set to specs -- is this verified with clear tube test?
What air filtration system is fitted -- Air box? Pods?
Are valve clearances within specs?
Good Luck!
- bountyhunter
- Thank you received: 337
- jeffff
- jeffff
- Hogslayer
- PUFF DADDY
- Thank you received: 1
- jeffff
Are pods breathing clearly? Not over-oiled?
If doubt, could test run without pods.
Proper NGKB8ES sparkplugs, gapped to specs?
Good Luck!
Has function of automatic advancer been verified with strobe type timing light to assure it's freely and instantly moving back and forth with changes in rpm by blipping the throttle? Wanting to assure the advancer isn't stuck or hanging or otherwise malfunctioning.
Good Luck!
- jeffff
- bountyhunter
The post in ENGINE section labeled:i'm sorry i have no idea what your trying to tell me by duplicate thread or the rest. Please clarify. THANKS
BLACK SOOTY PLUGS
That's a duplicate of this thread.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
Build Thread
