- Thank you received: 2
cleaning and paint removal? BS34
- pburnhamb
15 Apr 2009 16:25 #282065
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
cleaning and paint removal? BS34 was created by pburnhamb
I picked up a set of BS34s from the boneyard the other day. the guy told me not to mess with the diaphrams because that is how they get ruined. I want to clean these things out and get all the black paint off, but he has got me too nervous about the rubber diaphrams to do it.
if i take the tops off the carbs and take them all apart am i going to dammage the diaphrams? are new ones an arm and a leg...$$$....?
also any tricks for taking the black paint off and making them look new again?
thank you.
thank you.
1976 kz900
1977 xs650
- KawiConvert
- Thank you received: 4
15 Apr 2009 18:22 #282093
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic cleaning and paint removal? BS34
Yes, the diaphrams are an arm and a leg. I don't know about handling, but I imagine if you are careful with them and don't throw them in the bottom of your toolbox you should be fine.
Soak in lemon juice and it will eat the paint over a day or two. Lots of lemon juice.
- RonKZ650
- Thank you received: 240
15 Apr 2009 19:06 #282102
by RonKZ650
Replied by RonKZ650 on topic cleaning and paint removal? BS34
I'll wager one or more diaphams are already bad as the carbs sit, so you might as well bite the bullit and take them out and at least inspect them. You'll probably have to replace all 4 either way. They are not all that expensive, $600-$650 will get you all set. Gotta love the CVs. My only motorcycle with CVs is the 84 Honda Goldwing and I made the mistake of cleaning the carbs and not replacing the diaphrams. Everything was great, then next year ran like crap and I find 2 diaphrams had cracked. My wife in her wisdom said "replace all 4". I say $180 each? I replace only the 2". Next season runs like crap, and I get the "told you so" from the wife as I spend 6 hours and $400 more to replace the other 2.
- otakar
16 Apr 2009 04:45 - 16 Apr 2009 04:47 #282179
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic cleaning and paint removal? BS34
The diaphragms are an integral part with the slides and are about $65 each. They are not as delicate as people may make you think. just remove the tops and they slide right out. Inspect them carefully and if you find no holes you are OK. Put them aside and go to town on the rest of the carbs. I have a special math that cleans the carbs, and removes all paint. If you are interested I do complete carb overhauls for those carbs for $250 this includes jetting and mods for Pod filters. It would not include new slides if a diaphragm is bad. Here is a picture of some I have done. My turn around is 10 business days. You can email me at otto@condormodels.com
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Apr 2009 04:47 by otakar.
- JMKZHI
- Thank you received: 48
16 Apr 2009 07:45 - 16 Apr 2009 07:45 #282217
by JMKZHI
Replied by JMKZHI on topic cleaning and paint removal? BS34
Not sure if this will be of any use, but just in case...
Motoallparts sells diaphragm repair kits for KZ440s & some other bikes (Hondas, Yamahas). A how-to w pics is included in the item descriptions. The guy lists the measurements & some of them look suspiciously similar to each other, so I kinda wonder if any of them will fit other bikes. Or, maybe he can get what's needed for other bikes, if enough requests are made. I contacted him about a 750-Twin but he didn't know if any of them would work.
Search ebbaayy for KZ440 diaphragm rubber.
Last edit: 16 Apr 2009 07:45 by JMKZHI.
- JR
- Thank you received: 449
16 Apr 2009 14:36 #282315
by JR
Replied by JR on topic cleaning and paint removal? BS34
Go for it. Nothing to be scared about
I clean out my CV carbs every year and the diaphragms are just fine.
Take the tops of and take em out. Just be a tad on the gentle side. Inspect and put aside while you work on the carb bodies.
- pburnhamb
16 Apr 2009 15:05 #282321
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic cleaning and paint removal? BS34
thanks for the help guys, and encouragement. OTAKAR- where did you find the diaphrams for $65?
I am using pods, but these will go on my 650-810... got them off a gpz 750. Im hoping to get them ready to go while my cylinder block & top case half are at the machine shop.
1976 kz900
1977 xs650
- otakar
16 Apr 2009 15:16 #282322
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The 34s would be a bit too big on the 650 but really nice on a 810. I found the slides here.
www.mikesxs.net/products-75.html#products
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- pburnhamb
19 Apr 2009 11:03 #283088
by pburnhamb
1976 kz900
1977 xs650
OK, all the diaphrams are out and I havn't found any holes/dammage. NOW for the paint removal.... will this lemmon juce deal really work. is it ok to dunk the assemblies/ all 4 bodies?
the other option is this aircraft stripper i have. its made for aluminum paint removal, just not sure what it will do to the little rubber boods on the outside butterfly linkage.... if i go this route i'll put the tops back on as well as the bowls and tape up the air filter and intake openings and spray with caution.
any ideas????? good or bad idea? opinions?
thank you
thank you
1976 kz900
1977 xs650
- otakar
19 Apr 2009 11:36 #283096
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Lemon juice will corrode the Aluminum and Paint remover will dissolve anything that is not metal. I use a mixture of Try-Butyl-Ether, Delimonene, Butyl-Alcohol and Ester-Ether to clean carburetors. This removes all residues and will not harm the plastic pieces on a carburetor.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Bicycle Lee
19 Apr 2009 14:10 #283114
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic cleaning and paint removal? BS34
Does that spray engine cleaner work? I'm getting a set of vm28's in the mail that will need a good cleaning. I was thinking I would spray them down with the engine cleaner and then scrub and pressure wash them. Any thoughts?
Sorry to bumrush the topic, I just thought it was along the same lines...
1978 KZ1000 police
- otakar
19 Apr 2009 17:26 #283147
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
If it is just a simple HD cleaning than YES most definitely. Spray-um-hose-um. This should work fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
