33mm smooth bore carbs
- BigBlockT
13 Mar 2009 17:42 #271692
by BigBlockT
33mm smooth bore carbs was created by BigBlockT
I know this has been brought up some time ago but does anyone know which one of the ports between the carbs are vents and which one is a vacume port haveing trouble finding this info. thanks
- mark1122
- Keep twisting it
- Thank you received: 109
13 Mar 2009 20:00 #271732
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic 33mm smooth bore carbs
there all vents. there are no vacumes on vm33's. go to sudco for parts diagram. if u cant find any pm me. i have them.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BigBlockT
14 Mar 2009 06:05 #271816
by BigBlockT
Replied by BigBlockT on topic 33mm smooth bore carbs
mark1122 I sent you a pm.
- Old Man Rock
- Thank you received: 225
14 Mar 2009 07:05 #271834
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 33mm smooth bore carbs
Just out of curiosity... Not that I require mind you, new carbies on mine...
Does Sudco also offer carb re-builds by their technicians?
I know they have re-build kits and such, do the pre-jetting on the Mikunis and Keihins they sell to distributors (aka... Dynoman) but was wondering if they also do repairs and re-builds...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
14 Mar 2009 21:56 - 14 Mar 2009 22:14 #272025
by kzz1p
Replied by kzz1p on topic 33mm smooth bore carbs
Last edit: 14 Mar 2009 22:14 by kzz1p.
- kzz1p
14 Mar 2009 22:13 #272034
by kzz1p
- timebomb33
14 Mar 2009 22:30 #272046
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 33mm smooth bore carbs
it would be the last set, the first diagram are flatslides.
- BigBlockT
15 Mar 2009 04:25 #272059
by BigBlockT
it is the last set,now which one of the ports between the carbs are vaume and which are vents?
- mark1122
- Keep twisting it
15 Mar 2009 05:06 #272061
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
There are no vacuum ports just vents’.u can see the vent tubes i have on these the other 2 carbs have the same port so they would be vents as well. i could not sync these. u would have to drill the manifolds and glue in some nipples. mine ran fine with a bench sync. as do my RS34's.
what would be the advantage of porting the bell mouth as u can see in this pic? i'm thinking it may have smoothed airflow and in turn, improved the signal? i bought these in 1980 of a road race bike.
did u get the file i sent? i need to convert the pdf so i can extract the page u need some how??? anyone have knowledge of were i can download a free file converter?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
15 Mar 2009 05:11 #272062
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
15 Mar 2009 05:14 #272063
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Here is a page from Greg Copes tips (i think thats his name,big racer back in the day). this can be found at APE's web site now.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BigBlockT
15 Mar 2009 07:32 #272082
by BigBlockT
mark the port I'm refereing to is the one on the third carb in from the left in your pic right behind the spring I was told that one needed to be capped off according to what other page shows I need a 15 pilot jet right now I have a 20 can't remember right now what main jet I have.
