Vacuum Petcock
- rkan
05 Mar 2009 16:26 #269884
by rkan
1978 KZ650B
Vacuum Petcock was created by rkan
I have a '78 KZ650 and the petcock on it is vacuum operated and is supposed to let the fuel flow in the on position only when its running right? However when i disconnected the fuel line from it while it was in the on position, fuel flowed freely through it and it made taking the tank off a really big pain in the ass. I tried the Prime and Reserve positions too and it didn't matter, the fuel still flowed. Can it be disassembled, cleaned and rebuilt to fix it or should it be replaced? Any help is very much appreciated!
1978 KZ650B
- N0NB
- Blue handles better
05 Mar 2009 16:59 #269890
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Vacuum Petcock
Yes, it can be repaired with a rebuild kit. While that should fix the problem, it's no guarantee. I kitted two and both started leaking from where the elbow goes into the petcock main body. I gave up and bought the Pingel adapter plate and cheap manual petcock from
Z1 Enterprises
and have been pleased with the results. It does require some filing to the tank as the new petcock is round and is larger than the stock tank opening. The vacuum port on the #2 carb is then plugged off.
BTW, welcome to the forum.
Nate
- grumpy56
- Thank you received: 6
05 Mar 2009 18:34 #269904
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic Vacuum Petcock
Kawasaki still stocks the OE petcock, at least for the 1000. Over $100 though.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- RonKZ650
- Thank you received: 240
05 Mar 2009 20:09 #269928
by RonKZ650
Replied by RonKZ650 on topic Vacuum Petcock
You can buy the diaphram kit for $10-$15 and will fix this problem every time. Don't bother dissassembling, trying to clean ect. It won't work. New one works every time.
- Thank you received: 2098
06 Mar 2009 01:11 - 06 Mar 2009 01:49 #269961
by Patton
Replied by Patton on topic Vacuum Petcock
This petcock repair kit from Z1E should correct the problem.
Click here > Petcock Repair Kit
Z1E also offers the diaphragm alone > Diaphragm .
I would recommend using the full kit instead of just the diaphragm alone, especially where any doubt exists as to exactly which component is responsible for the leak.
Good Luck!
Good Luck!
Last edit: 06 Mar 2009 01:49 by Patton.
- 76 LTD
- Thank you received: 1
07 Mar 2009 18:00 #270279
by 76 LTD
Replied by 76 LTD on topic Vacuum Petcock
Save your self a lot of time and trouble just go ahead and buy an after market petcock and the pingle adapter.then when you turn it off its off.might also kep you from getting a crank case full of gas!
- Locozuna
07 Mar 2009 18:26 #270283
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Vacuum Petcock
If I was gonna spend $100 on a petcock it would be a Pingle. High flow, smooth as silk , reliable as a spoon and big bling factor.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- gane
07 Mar 2009 18:37 #270286
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Vacuum Petcock
Like the little girl with the little curl, 650 vacumn petcocks are either very good, or shitty. the fat oring on the face of the diaphram #26 is failing to seal. whether problem is petcock body, diaphram, spring, or check vlve in diapham plate is your' guess. I've tried 6 or 7 rebuild kits, w/@ 50% success. If there is an accessory manual petcock, or oem (early model OE or other ) petcock which bolts up, I would go with it. Vm carb float valves meter fuel pretty well in running, but are poor when sitting with a 4-5 lb presure head. luck G
- RonKZ650
07 Mar 2009 19:57 #270305
by RonKZ650
You can bolt up an original 1977 KZ650 manual petcock, but it's the same thing as replacing an electronic ignition with points, it's not worth a crap in the long run. Put the diaphram on and do it right it will work 100% of the time.
- N0NB
08 Mar 2009 07:00 #270343
by N0NB
Nate
Sorry, Ron. 100% is far too optimistic. 25 to 30% is more realistic and perhaps still far too high. Too many of these bikes were neglected along the way in their previous lives and the petcock body is just shot.
A more reliable fix can be found at Z1 Enterprises . To the OP, measure the mounting holes center-to-center, buy the correct adapter plate, and the $13 petcock will will work just fine on a 650. I've done three with no performance issues.
Nate
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
08 Mar 2009 09:11 #270362
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic Vacuum Petcock
Yep,
what NONB said.
I tried rebuilding several OEM vacuum petcocks and had 0% luck ZERO. Time and corrosion take their toll on these parts.
I Switched to the $12 Pingel with $12 adapter plate, and no problems since. Off is off, on is on, you just have to remember to turn it manually.
what NONB said.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- RonKZ650
08 Mar 2009 17:04 #270445
by RonKZ650
Well I'm still at 100% luck rebuilding, but only done about 5, but 5 out of 5 aint bad.
