carb rebuild and 1075 kit
22 Feb 2009 17:56 #267279 by cruspeed
carb rebuild and 1075 kit was created by cruspeed
I'm going to have to buy some carb rebuild kits and not sure which is best for me. I'm going to have a 1075 kit on my bike and I have a choice of what size of jets I need. Now thinking that the engine will pull more vacuum I will need smaller jets but here are the 2 kit sizes. I think the ebay kit will work for me but need some advise before I do anything. I don't live in the mountains if that matters.
(Z1)
Main Jet 105 and 107.5
Pilot Jet 15 and 17.5
and
(ebay)
Main: 105
Pilot : 17 & 15
78 KZ1000 project X 2
22 Feb 2009 17:59 #267282 by timebomb33
Replied by timebomb33 on topic carb rebuild and 1075 kit
you will need bigger mains than that, i'd recommend at least 115 or 117 to start the pilots use the 17 or go to a 20 pilot
I THINK MY POWERBAND BROKE
22 Feb 2009 18:13 #267292 by roy-b-boy-b
Replied by roy-b-boy-b on topic carb rebuild and 1075 kit
I agree with timebomb. Roy
23 Feb 2009 14:33 #267527 by keith1
Replied by keith1 on topic carb rebuild and 1075 kit
me too....117 and 20
23 Feb 2009 16:11 #267546 by Joe77A1
Replied by Joe77A1 on topic carb rebuild and 1075 kit
I've got to clean and rebuild the carbs on my '77 KZ1000A1 . Any recommendations on high quality carb kits and where to get them ?
23 Feb 2009 16:27 #267551 by Patton
Replied by Patton on topic carb rebuild and 1075 kit
Z1 Enterprises would be my first choice.
Here's the carb kit, just click > Z1E Carb Kit
Good Luck! :)
  • DoubleDub
  • Visitor
29 Jun 2009 19:33 #303218 by DoubleDub
Replied by DoubleDub on topic carb rebuild and 1075 kit
Not to hijack an old thread, but I just had my 900 turned into a 1075. I'm running the stock airbox with a K&N filter and an unknown 4-2 exhaust. I'm running the stock cams. Carbs are the stock VM26 carbs from the Kz900. I increased the main jet to 120 and left the pilot alone. It starts and idles fine. Drives okay until I lay on it and then it hits a wall hard at about 6000-7000 rpms. Would this typically be a lean condition versus a rich condition? I thought I would be too rich with the 120 main versus to lean.
Thanks, guys!
29 Jun 2009 19:45 #303227 by Patton
Would test run with fuel cap ajar to rule out possible fuel starvation due to clogged vent in cap.
Also check for clogged petcock screen or clogged in-line fuel filter.
Good Luck! :)
  • DoubleDub
  • Visitor
29 Jun 2009 19:46 #303228 by DoubleDub
Thanks, guess you are also thinking I'm hitting lean at that rpm. That helps me troubleshoot!
29 Jun 2009 20:19 - 29 Jun 2009 20:20 #303247 by Patton
Oem Mikuni 26's on KZ900 are very user friendly carbs. And generally perform quite well over a fairly wide spectrum of mods. Kawasaki kept 26's on the KZ1000's in 1977 and '78.
Am running a 1015 KZ900 with airbox K&N and 4>1 Kerker with oem 26's in standard configuration, and enjoying strong performance throughout the throttle range.
26mm (VM26SS) KZ900A4 & A5
Main Jet 115
Air Jet 1.0
Needle Jet O-6
Jet Needle 5DL31-3 (middle clip position)
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5
Air Screw setting 1 3/8 turns out (beginning)
Maybe the extra 60cc is too much for the 26's, but I wouldn't give up on them quite yet. At least not before ruling out most everything else.
Good Luck! :)
Last edit: 29 Jun 2009 20:20 by Patton.
  • DoubleDub
  • Visitor
30 Jun 2009 06:02 #303317 by DoubleDub
Thanks for the info, Patton. I'm pretty sure my exhaust is more restrictive than your Kerker, so I'm betting I could use a similar setup and run fine. This confirms (for me) that I overshot the main jet and should be running extremely rich at WOT. I must be having a fuel starvation issue. I'll have to start back at square one and troubleshoot.
Thanks again!
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
30 Jun 2009 22:23 - 30 Jun 2009 22:31 #303546 by kzz1p
Replied by kzz1p on topic carb rebuild and 1075 kit
When you have it WFO and it hits the wall, apply the choke. If it runs better, use larger jetts. If it runs worse, use smaller jetts.
You can also try:
Go along in 5th gear at about 45-50 mph, pull it wide open and hold it. If it picks-up and goes, main jet is okay. if it falls on it's face, use a richer jet.
Last edit: 30 Jun 2009 22:31 by kzz1p.
