VM26 carbs with Accelerator pump-Won't idle down.
- wiredgeorge
Re: VM26 carbs with Accelerator pump-Won't idle down.
04 Feb 2009 07:17
The return springs on a Z1 can not be left off the carbs as they have no way of closing. These return springs go around the throttle shaft and on early Z1s there were two springs and they are VERY stout... too much effort is needed to open them in my opinion. When they got to the 76 KZ900, a different arrangement of spring is used. There is a single return spring. There are actually two springs used... one for the larger VM carbs and another for the VM24. The spring from the VM24 will not adequately close the larger carbs as its pull is too weak. Some springs seem to get stretched over time or weak and won't adequately close the throttle and the bike's idle won't come down. The spring must be replaced. I buy these springs in bulk from an aftermarket source for use in my business and they are only a buck or two each (unlike the OEM). The secret is to find one the same length and same wire gauge. You can likely find an appropriate spring at your hardware store if you take you old spring down and compare. Most hardware bought springs don't have the swivel-hooks that the OEM spring has but have closed loop ends and these work just fine. If you test a LOT of carburetors, you will begin to feel a week spring immediately. First time it happened to me, I was at a loss as to what was going on as the bike wouldn't idle down and once figured out, there is a distinct feel to a week spring even while tuning the carbs before riding.
- KruZer
04 Feb 2009 08:29
Thanks to both of you for continuing to give me thought and insight into these issue.
I agree that the OEM spring is highly over priced so maybe I'll look around for an aftermarket unit.
Thanks again,
Buzz
Thanks again,
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- KruZer
15 Feb 2009 13:46 - 15 Feb 2009 13:50
Well the KruZer is back on the road and running great!
Thanks to all of you for the suggestions and help with the idle down problem.
Turns out it the problem was a stretched throttle pully return spring. I bought a new spring (OUCH!), adjusted the accelerator pump linkage and wham...what a difference.
The bike has been used for a dragbike for the last year and half but I decided to put the bike back on the street and build a bike for the track.
I've attached a couple of pictures.....
THANKS AGAIN!!!
(I tried to attach a few pictures but I could only get one picture to attach...)
Buzz
THANKS AGAIN!!!
Buzz
Last edit: 15 Feb 2009 13:50 by KruZer.
- timebomb33
17 Feb 2009 22:53
hey what triple trees are those looks like they have quite a bit of offset built in to them.
I THINK MY POWERBAND BROKE
- nads.com
18 Feb 2009 01:21
THANKS AGAIN!!! Those corbin seats with the big backend look gawdy. How could a seat company do that ?
Buzz
- KruZer
18 Feb 2009 15:12
You're right. Custom triple trees with a 5 degree rake. The triple trees are drilled for Harley handle bar spacing and I use a set of
1-1/4 dragbars and an early model Sportster headlight...
Buzz
Buzz
