Some carb ?'s
- sbulla
- 1980 KZ1000 LTD
First, the manual states that I have VM26SS Mikunis (with the accelerator pump) and the picture in the manual correlates to what I have on the bike. I assume that means they're 26mm throats but, I measure closer to 28mm ID on the engine side. Is that where the measurement is supposed to be or is it inside where the slide is?
Next, as I'm not the original owner of this bike, I was curious as to what jets they had in them as the plug readings I've been getting seem to be a bit rich. The jets are 115's. For stock the manual lists 102.5. I'm running the stock airbox (with K&N element) and a Kerker 4-1 exhaust. Anyone running this combination that could give me a jet size more appropriate?
Also, one of my jet needles seems to be a bit pitted down near the tip. I can barley feel it with my finger nail. Would this affect performance much or should I try to find a replacement?...and, where would I find one?
Guess that's enough questions for now,... stand by for more though.
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
- MFolks
- Thank you received: 540
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- sbulla
- 1980 KZ1000 LTD
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- roy-b-boy-b
- Thank you received: 103
Wired George's probably has a carb I.D. section on his site. Roy
- timebomb33
- sbulla
- 1980 KZ1000 LTD
Measure the carbs on the engine side. Inside diameter on the carb. There should be a number on the outside of the carb down near the float bowl. It is hard to see.
That's where I measured with my calipers. Don't have an inside micrometer but, it's definitely bigger than 26mm.
Looked all over the carb with a magnifying glass...couldn't see a number.
Couldn't find the carb I.D. section on WG's site either.
Thanks,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- sbulla
- 1980 KZ1000 LTD
wern't z1-r carb's 28mm. any way the jets you might want start out with are 117.5 mains and 17.5 pilots and i usallay put my clips in the 3 rd position
117.5? I'm running 115's now and it looks to be rich. I'm confused.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Thank you received: 2098
Sonny
If not already done, would first assure ignition and compression are up to specs before blaming carbs.
Good Luck!
- sbulla
- 1980 KZ1000 LTD
Good Luck! [/quote]
Oh yeah, compression is OK and I have battery voltage at the coils with good spark. There really is no big problem that instigated this tear down. I just purchased the bike and was curious as to what I had and figured a good cleaning was probably in order.
My plug readings show just a bit on the rich side and the idle was set too high as the idle screw was screwed all the way out so, I thought after a valve check, I'd pull the carbs and clean them, do a bench sync, and start from there.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- wiredgeorge
