Slight hesitation when throttle is first opened
- ghunt81
Anyway, it's running great now, fires up on the first crank (I love that Dyna coil!).
Only problem that I have noticed is that it sputters/hesitates a bit when you first open the throttle and/or have it barely open. It's really not even noticeable in first-third gear, but you definitely notice it in fifth when you're trying to cruise with the throttle barely cracked. There are no problems at any throttle position above that.
What should I be looking for that might be causing this?
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
- bemoore
- Thank you received: 4
77 KZ650C1 w/Kerker 4-1
- ghunt81
I have the screws at 1 1/2 turns out, which is what they were before and it ran good like that.
Also I think you turn them out to richen the mixture?
- twinkyrider
78 kz1000A
Fond du Lac,WI
- The Milkman
- Thank you received: 194
Nope, I still have the stock airbox. Carbs were just rebuilt.
If your adjustment screws are on the side of the carb they are air adjustment screws,, you turn them in to richen the mixture. If they are underneath in the front they adjust the fuel, you turn them out to richen the mixture.
That off idle stumble is usually the mixture being to rich to begin withand when you open the throttle it leans the mixture suddenly.
Seeing as how they were recently cleaned and rebuilt the passages will be cleaner.
Try leaning the mixture 1/4 of a turn, if performance deteriorates, go the other way.
- arai59
- Banned
- ghunt81
I turned the air screws out 1/4 turn on both sides.
I noticed no noticeable improvement in driveability, but it was popping from the exhaust more at idle. I turned the screws back in to their original position of 1 1/2 turns.
I have not yet tried turning them in another 1/4 turn but I will try that sometime.
- bountyhunter
- Thank you received: 337
NO, he has a 750 twin like mine. The mikunis have the pilot screws on the sides and you back them out CCW to get richer (more gas).ghunt81 wrote:
I also recommend checking float adjustment (gas level) using clear tube method. A stumble when you open th throttle at lower RPM is the classic symptom of too low fuel level in the bowl.
- bountyhunter
I forgot to really reply to this (and the weather was crappy so I didn't ride much).
Won't help. Check fuel level and check for air leaks. Check to see if you have 45 pilot jets, because 50's run better (a little richer).
As last resort, you can raise the needles one notch and it will give you better throttle response.
- ghunt81
And yeah I do have #45 pilot jets...that's what came in the rebuild kit. Spose I could swap to 50's easily enough.
- bountyhunter
I actually did check the float level a little while back and both were good, and right within spec.
Did you check the fuel level with a clear tube?
- ghunt81
