2nd cylinder running at 3000 rpm or higher
  • GargantuChet
  • GargantuChet's Avatar
Re: 2nd cylinder running at 3000 rpm or higher
14 Feb 2006 06:35
#23774
Oops... Thanks George.
Wow, that's dedication... I promise not to tell the Mrs. that you snuck on here the morning of your anniversary!
:laugh:
  • xr350guy
  • xr350guy's Avatar Topic Author
14 Feb 2006 08:51
#23797
if there are more than one carb, they need syncronizing because you want the mixture to be the same on all cylinders.
  • GargantuChet
14 Feb 2006 09:06
#23799
I thought the manifold vacuum took care of making sure that each cylinder got exactly what it needed. I've never touched a CV carb, though.
  • wiredgeorge
  • wiredgeorge's Avatar
14 Feb 2006 11:24
#23811
I have to get on the Internet almost every day as part of my business... I will be taking the missus out for dinner this evening hehe Be a nice evening to take a bike ride I think.
As far as CV carbs, vacuum diaphragms are very sensitive to differences in vacuum in each cylinder. Since each cylinder has a slightly different amount of compression, each cylinder will generate different amounts of engine vacuum and this must be compensated for...
