In need of a petcock handle
26 Jun 2008 14:02 #222361 by slowman
In need of a petcock handle was created by slowman
I'm starting to get sick of turning my petcock on and off with a flathead screwdriver. :D
I have a non-vaccum petcock with On, Off, and Res. It mounts in along with a spring (which I don't need), and stays in place using a single phillips head screw from the bottom. If anyone has one, I would greatly appreciate it. Send a private message and let me know what you want for it!
Thanks! :)
1979 Kawasaki KZ1000 LTD
The only thing better than the sound of a carburettor opening is the sound of 4 carburettors opening simultaneously!
26 Jun 2008 17:03 #222382 by bigkaw815
Replied by bigkaw815 on topic In need of a petcock handle
Ditto for me. The metal handle of the petcock came off from the plastic part inside. If someone has another "extra one"please let me know. Thanks
26 Jun 2008 17:54 - 04 Dec 2008 06:57 #222389 by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:57 by JMKZHI.
  • jdsmithinc
  • You want some of this? Huh? Do ya?
26 Jun 2008 18:36 #222397 by jdsmithinc
Replied by jdsmithinc on topic In need of a petcock handle
I dont know what kind of bike you have but I have a spare from a Z1 900 if it will work. Send me a pm with your number and I will call you about it. Joe
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
Mustangs, too many to list on here (I like to rip the pieces of junk apart)
Located in Shelby, N.C.
If life gives you lemons make lemonade, then find someone whos life was given vodka and have a party.
  • jdsmithinc
26 Jun 2008 18:38 #222398 by jdsmithinc
Sorry I assume you have a kz1000. I dont know if it will work but if it will let me know.
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
26 Jun 2008 19:04 #222411 by slowman
Replied by slowman on topic In need of a petcock handle
Forgot I had this picture... :D
26 Jun 2008 19:07 #222412 by RonKZ650
Replied by RonKZ650 on topic In need of a petcock handle
I think any manual petcock lever from a Z1, KZ900, KZ1000, KZ650 ect, will have the same basic lever. The lever may be slightly longer or shorter length depending on model, but mechanically will work. This setup was the biggest piece of horsesheet Kawasaki ever saw fit to use, as the levers always seize up and that little extra effort to move the lever will break it right off. If they don't seize, they leak. The leak is what dries up the grease and makes them seize actually and you can replace that oring till you're blue in the face, they will still leak and seize :S
  • jdsmithinc
26 Jun 2008 19:09 #222413 by jdsmithinc
The handle on mine may work. The petcock itself has two outlets for fuel feed (not vaccume). Send George a PM and see if they are the same. Mine is from a 75 Z1 900.
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
27 Jun 2008 03:50 #222473 by slowman
I don't know who George is, I haven't been here long enough to know the names behind the screen names. :D
Is there another option to simply replace the whole thing? I would think the aftermarket would take care of this problem.
27 Jun 2008 04:50 - 04 Dec 2008 06:59 #222482 by JMKZHI
del
Last edit: 04 Dec 2008 06:59 by JMKZHI.
27 Jun 2008 08:51 - 27 Jun 2008 09:07 #222502 by patmann
Replied by patmann on topic In need of a petcock handle
Pingle makes one that people claim is better than sliced bread. Either someone on here will help you out with the details, as I believe there is a plate or something this is also required. OR call Jeff & company @ Z1 Enterprises.
Here's a link that might help..
www.z1enterprises.com/reference/petcock.aspx
"George" is wiredgeorge , that world renowned carb guru, and teacher of all things related to motorcycle carbs;)
He's a MAJOR figure around here.
Good luck! Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Last edit: 27 Jun 2008 09:07 by patmann.
29 Jun 2008 13:36 #222868 by Mark Wing
Replied by Mark Wing on topic In need of a petcock handle
I've drilled and glued new pins in and they work fine. I use a piece of coat hanger for the pins.us
Yorba Linda Cal.
