Carb issues I need some advice.
- PhildoBaggins
09 Apr 2008 11:50 - 09 Apr 2008 15:06 #205225
by PhildoBaggins
1975 Kawasaki Z1B Cafe (Project)
1979 Yamaha Xs400 Cafe Daytona
Carb issues I need some advice. was created by PhildoBaggins
1975 Z1B
Top end has KZ1000 Cylinders
KZ900-A4 Carbs (three screws on top)
Pod filters
Accelerator pump
Main jet: 120
Pilot : 17.5
Hey guys I recently rebuilt the carbs include the Accelerator pump. I finally got the bike to start only issues now are i cant seem to get the idle to settle close to 1000 without dying out. It seems to be running real rich. When i rev the thottle it acts like its real bogged down. I checked the float levels I dont have a tool to check the exact height.I cant seem to adjust the air/fuel mixture screw enough to make it lean enough. I do all my adjusting after its been running for a few mins and the choke is completely off.
My guesses:
1) the float levels are too high
2) The jets
My questions are:
Its there a chart i could look at to go down a few jet sizes and see if thats the reason for the bike running so rich.
Its there a cheap and easy way to check my float levels that have drain plugs coming out the sides If so whats the proper height?
If this helps the orginally owner of the bike bought it from someone who rebuilt the entire bike to be a drag bike. (i.e. extended swingarm,rebuilt motor with KZ 1000 top end) The carbs aren't stock according to the jet sizes at least. These are much bigger.
Pod filters
Accelerator pump
Main jet: 120
Pilot : 17.5
My guesses:
2) The jets
My questions are:
Last edit: 09 Apr 2008 15:06 by PhildoBaggins.
- 76 LTD
- Thank you received: 1
09 Apr 2008 19:06 - 09 Apr 2008 19:08 #205317
by 76 LTD
Replied by 76 LTD on topic Carb issues I need some advice.
I have been having almost exactly the same problems with my 79 1000 check to see if accelerator pump is working mine wasnt .the check ball between the float chamber and the pump was stuck and wouldnt let fuel into the pump.i got that fixed but it still acts like its runniing rich at idle and low speed.if i back the air screws out more than 1/2 turn it willl just load up and die.when ya figure it out let me know LOL.BTW im running stock 112 mains and 17.5 primaries.
Last edit: 09 Apr 2008 19:08 by 76 LTD.
- wiredgeorge
10 Apr 2008 05:22 #205379
by wiredgeorge
Replied by wiredgeorge on topic Carb issues I need some advice.
The carburetors are not from a KZ900A4. Sound like a later (79/80) KZ1000 perhaps. Adjust the fuel level with a clear hose held next to the side of the bowl. You can find a 1/4" STRAIGHT vacuum fitting and insert it into the bowl after removing the screw and then just thread it in... it will drip just a tad but not enough to affect the reading. Hold the tube next to the outside carb with the rack exactly level and when gas fills the bowl, it will fill the tube. Knock out or blow into the tube to dislodge any air bubbles. The fuel level should be about 1/8" below the bowl gasket mating line.
- PhildoBaggins
10 Apr 2008 06:37 #205390
by PhildoBaggins
Replied by PhildoBaggins on topic Carb issues I need some advice.
I was just going with the picture on the Z1 website its the closest looking one to my carbs. But i did read on the other thread that i could try adjusting my fuel air mixture screw to 1/8th turn. Ill check the floats and that 1/8th turn and see what happens.
Question how long should the clear tube be to check it with?
- BSKZ650
- Thank you received: 14
10 Apr 2008 07:09 #205399
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Carb issues I need some advice.
dosent really matter how long it is ,,, needs to be higher that the carb bowl thats all
- School Teacher
10 Apr 2008 09:14 #205419
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic Carb issues I need some advice.
get a pic of the carbs on so they can help with the id of the carbs
1980 kz1000G1
- wiredgeorge
10 Apr 2008 12:18 #205466
by wiredgeorge
LTD 76, stock jetting for the KZ1000A/B 79/80 pumpers is #15 pilot and #102.5 mains.
- wiredgeorge
10 Apr 2008 12:21 #205468
by wiredgeorge
- PhildoBaggins
10 Apr 2008 12:37 #205472
by PhildoBaggins
Thanks a lot wb. If it helps out any on your website in the tech stuff index the picture you have for the VM carbs is nearly exactly like that except mine have two fuel inlets between 1 and 2 and 3 and 4 with no vacuum fitting there at all. other than that it has the idle adjustment on the top side.
- PhildoBaggins
10 Apr 2008 16:03 #205519
by PhildoBaggins
I checked the float levels and all seemed to be in the right range. There was a check ball in the third carb I took it out didn't think it was suppose to be there ( i could be wrong. I adjusted the fuel air mixture screw to 1/8th turn and it fired right up.
i can get it to idle at 1800 and it will go down to 1100 but it wont settle just kinda fluctuates.
Any ideas?
Any ideas?
- 76 LTD
10 Apr 2008 18:28 #205554
by 76 LTD
Thanks George i was going on what P.O.told me.still shouldnt load up at idle tho i guess i will check the floats and go from there.the carbs were cleaned and checked by local Kaw. dealer about 4 years ago.been stored dry until about a week ago.
- wiredgeorge
11 Apr 2008 06:01 #205669
by wiredgeorge
If you have an accelerator pump, there are check valves in each carb bowl. These are visible on the bowl gasket mating edge. The check valve is a "bb", a small metal sleeve and a circlip. If the check valve isn't in place, that carburetor bowl will FLOOD with gas. In the #2 bowl, there is ANOTHER check valve which is down in the bottom of the bowl and not visible. If this valve is stopped up (and often is), no gas will get into the pump part and thus won't go into any of the the other carbs. The hole that feeds this check valve is VERY small. Most shops will not know how to clear this bottom check valve, if it is plugged up.
