- Thank you received: 337
Please help me with my 77 KZ1000
- bountyhunter
Are you using fresh gas?
That bears repeating. if the gas was old, you'll need to flush the system from the tank down through the bowls.
- 77kz1000rider
any suggestions as far as the whole suddenly dying thing? im at a standstill now but morale is up because it actually ran and i rode it for the first time in 2 years
thanks to everyone
- 77kz1000rider
i have it seated 2 and 1/2 turns out from the fully tight positon
just thought i would add that in there as well maybe that will lead to some helpful hints that you guys are so well with giving, thank you again
- bountyhunter
great news everyone!!!! the bike started and ran today with some fresh gas and a little bit of starting fluid, i rode it in my yard for about 5 minutes then it just died, but there is hope now, i got it running
thanks to everyone
make sure the air vent on the gas cap is clear or it will vapor lock and die every few minutes. Guess how I know that......
- 77kz1000rider
- EddieBoy
- Thank you received: 1
i might also look into a motorcycle safety course
- 76 LTD
- 77kz1000rider
thanks
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- mark1122
- Keep twisting it
- Thank you received: 109
if that is good i would check the float seals next.remove the bowl drain and make sure u have a good fuel suply coming out of each drain. if u push up VERY lightly on the floats the fuel should stop flowing.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
