- Thank you received: 4
79 kz650 carb parts and boil
- KawiConvert
Also, is it safe to boil these in a chemical dip? I have pulled the main and slow jets, choke assembly, tops , slides, float assembly, and air screw. Is there something else that is inside that I am missing?
Also, in the bowl with the pump on it, there is still a rattle when I shake it. I removed the ring, ball, and pin that was in all 4 bowls, but haven't found what is still in the pump bowl (pump assemblies are removed).
After reading some previous posts I am going to be using a 110 and 17.5 as recommended (I am using pods and a different exhaust (with baffles in).
Any help is greatly appreciated. I am trying to get it running as soon as possible while working on the seat and tank to make it a bit more mine.
Thanks for the help.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- KawiConvert
- Bluemeanie
- Thank you received: 14
- KawiConvert
- Bluemeanie
- KawiConvert
Thanks for the info though, it is good to know what differences if any were made.
- ran429
- Master of FREE rides!
I need money for a set off a GPZ750
Post edited by: ran429, at: 2008/01/28 20:23
- KawiConvert
i have a set of each in rebuildable condition, all of the parts in them should help someone if they feel a need to want them.
I need money for a set off a GPZ750<br><br>Post edited by: ran429, at: 2008/01/28 20:23
I'll think about it, right now I am parting out my previous project bike that I spent the last 4 months on to raise funds for my current project bike. Just got a better set of carb boots so life is looking a little better. I'll see how salvagable my first set it, I may just need new carb bodies as the PO had trouble putting screws in without cross threading the holes (not that I'm bitter .
- bountyhunter
- Thank you received: 337
I picked up a set of 79 kz650 carbs (with pump) for my 78 and I haven't been able to find a carb kit that would fit. Does anyone know where I can find one? I would go to the dealer for the individual parts, but I need to rejet, new needles, gaskets, air screws, and o-rings.
Keystar made the carb rebuild kits for my 1979 KZ750. Do a google search on them and see if they make one for yours.
My service manual warns against using strong solvents on the carbs as the may have plastic parts inside. I use acetone spray to clen carb parts.
- mariozappa
- Thank you received: 8
Wouldn't you consider acetone a strong solvent?
1977 KZ650C1
and the KZ650/KZ750 Conversion
- wiredgeorge
- KawiConvert
