Stong fuel smell.
- Cow_Man
Stong fuel smell.
25 Nov 2007 05:57
Hi, I just bought a 78 KZ 650. Overall in great shape. It doesn't have a owners manual. I noticed that the fuel valve does not have a shutoff position. It had RES, PRI, and MAIN. My garage has a strong smell of fuel and the bike would not start till I pulled and dried the plugs and cleared the cylinders. Then it started great and did after till it sat overnight again. Am I not setting the valve right or do I need a new one??
P.S. I don't find any fuel on the ground.
Thanks
Post edited by: Cow_Man, at: 2007/11/25 09:00
Thanks
Honda XL125
Yamaha RD250
Honda CB750A
Honda 1200 Interstate
Kawasaki KZ650B2
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
- KZErider
Re: Stong fuel smell.
25 Nov 2007 06:06
You probably need to rebuild the petcock or go to a different one. You could just install a shut off valve in the fuel supply line in the meantime. Also check to be sure your float valves are working properly.
Post edited by: KZErider, at: 2007/11/25 09:09
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- Cow_Man
25 Nov 2007 06:26
Yeah I thought it might be the petcock I have never had a bike without a shutoff before. I need to pull the tank and fix a dent this winter so a new petcock with a shutoff is in order I think. I just joined today and have been browsing the forums and found a thread on petcocks. I am amazed at the quality of technical advice here.
Thanks.
Thanks.
Honda XL125
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
- OKC_Kent
25 Nov 2007 06:27
The 3 positions are REServe, PRIme, and MAIN. Keep the petcock normally on MAIN. When the engine starts a vacuum will pull open a rubber diaphragm in the petcock allowing fuel to flow. When you shut off the engine the diaphragm shuts off the gas, in theory.
Reserve is for when you run out of the MAIN tank, and PRIME will bypass the vacuum shutoff feature allowing gas to flow directly into the carbs. This is handy if you have let the bike sit for weeks, or have a totally dry tank and just filled up.
Check Z1Enterprises on the right hand side of the screen and read the page about rebuilding petcocks.
Double check the oil level too, fuel has a way of getting into the crankcase. Open the oil cap and see if the oil smells like gas. If it does then you need to change the oil.
Cashion, OK
78 KZ650 B2 85,000+ miles
- OKC_Kent
25 Nov 2007 06:35
What model 650 do you have? I have a link to a 78 B2 model for the owners manual....even if you have a C or D model it should still work for you.
Let me know.
Also check out the link in my signature for more 650 stuff.
Kent
Let me know.
Kent
Cashion, OK
- Cow_Man
25 Nov 2007 06:43
I have a 78 650 b2.
Thanks for the info I will check it out. I am very impressed with the response and quality of technical expertise in this forum. Makes me a little misty thanks guys.
Honda XL125
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
- OKC_Kent
- Cow_Man
25 Nov 2007 07:30
Got it OKC_Kent. Thanks a bunch. It has a lot more info than the new ones.
Honda XL125
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
- RetroRiceRocketRider
25 Nov 2007 07:34
Welcome to KZr Cow_Man.
If you're planning on sticking with OEM parts and are going for a resto, be aware that the OEM petcock (51023-1023) for the '78~ KZ650 is no longer available.
In fact, the original part number has superceded 4 times (51023-1370, 51023-1011, 51023-1013, 51023-1005) over the years, and all of them now are no longer available. :S
When I replaced the petcock on my '78 KZ650-B2, I just checked what other current model Kaws used the same oval o-ring (51039-013) that mounts it to the tank, and then researched which petcock was still available.
The Kawi '05 KZ1000-P24 (last production year of the Police bike) just happens to use that same o-ring, and since it's newer than my '78, parts are still (for now) avaialble.
The petcock for the Police bike is a 51023-1375.
And aside from the obvious part number diff, the only things diff are the direction the fuel and vacuum fittings face coming off the back of it.
IIRC, when I bought that same petcock 3 years ago, it ran me around $85 +tax.
Of course you can always follow Kents suggestion in checking with Z1 Enterprises, which I believe is a less costly sollution. I've heard the Suzi petcock is comparable to the Kawi and a lot cheaper.
Post edited by: RetroRiceRocketRider, at: 2007/11/25 10:35
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- kwakagoose
25 Nov 2007 09:34Please Log in or Create an account to join the conversation.
- Cow_Man
25 Nov 2007 18:25
I just pulled the tank and drained it into a gas can. I put a hose on the vacuum and sucked on it to control the valve, it seemed to work properly. I think I will put on a valve with a shutoff anyway just because that is what I am used to. Thanks for all your helpful info.
Honda XL125
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
Yamaha RD250
Honda CB750A
Kawasaki KZ650B2
- jaguar
16 Dec 2007 11:32
And another thing! I you smelled gas strong,,, it could be that it drained into the float bowl and then into a cylinder and past the rings to dilute your oil. Check your oil for the smell of gas. If you smell gas, change your oil because it has been thinned by the gas. Dont want you spinning a bearing on a creampuff. Joe
