one carb vs 4 carbs
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Samwell
Re: one carb vs 4 carbs
12 Nov 2007 14:40
larrycavan wrote:
Oh Lord, the factory isn't always best. If it were, we wouldn't have nearly as much fun modifying our bikes to make them better! The factory does the best it can with the budget its given.
Sure 4 carbs give better performance than a single but that doesn't mean its a terrible idea. The old draw-through turbo kits used one carb. In fact, given our carbs are 30 years old, a new Mikuni HSR 42mm will flow enough air to supply your bike an might not fare so poorly against the 4 carbs.
If you can find an old ATP intake manifold (or buy one from mrturbo) then your fabriated is almost zero.
my 2 cents...
freebyrd24 wrote:i was thinking of switching to one carb, and making a manifold for the 4-1 intake setup. with running one carb, instead of the 4, what are the pros and cons of that? does performance suffer? im very curious if its even worth it. for now ill run n/a. thanks a lot!
Pros = one carb to adjust
Cons = performance hit, fabricating manifold, it will cost you more to go this route than to straighten out a set of stock carbs.
The ideal setup is a carb / throttle body & injector for each individual cylinder. That's how they came from the factory. They were / are performance designed engines.
Can it be done? Certainly it can. Ask yourself one question though. If it were better that way, wouldn't the factory have done that?
my 2 cents...
- larrycavan
12 Nov 2007 15:27
If anyone seriously wants to do a single carb and manifold setup, here's the specs for such a project. This is for a stock KZ1000
Runner lengths = 10.193" ( Cylinder Head Port + Manifold Runner )That's tuned to the 3rd harmonic. Best Power output. Want more torque but less peak HP, then use 14.601"
Plenum Runner Minimum Recommended Entry Area = 1.055 to 1.187 Sq.Inch
Plenum Runner Maximum Recommended Entry Area = 1.239 to 1.466 Sq.Inch
Have fun!
:whistle:
Have fun!
:whistle:
- Bluemeanie
13 Nov 2007 06:04
I don't understand half the tech stuff you guys are talking about and I agree with the other half :huh: But I do like the idea of one carb if it worked well!!
- Bluemeanie
13 Nov 2007 07:14
Hey guys, look what I found on ebay! Almost looks like a kit made for the bike! Holley is one of easiast carbs to work on too! What do you guys think? (Hear is your chance freebyrd24, bike is for sale!)
tinyurl.com/2nkvmn
Post edited by: Bluemeanie, at: 2007/11/13 10:16
tinyurl.com/2nkvmn
- freebyrd24
13 Nov 2007 07:46
Wow talk about different! great find! haha
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Sold:
