650 Airbox interchange???
  • rdgrnr
  • rdgrnr's Avatar Topic Author
16 Oct 2007 14:04
#176499
Hey all,
Does anyone know if the 79 650 Airbox will work on the 77? Or for that matter, are there other years that will interchange? I was also wondering where I might find the part # for the 77 to check it against boxes from other years as well..
Thanks,
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • rdgrnr
Re: 650 Airbox interchange???
16 Oct 2007 14:07
#176501
Ok I read anohter thread and I see I can go to Kawasaki to look it up...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • Bluemeanie
  • Bluemeanie's Avatar
16 Oct 2007 14:12
#176502
They should all be the same. The only differance I would think would be the hole in front for the emmision hose from the valve cover, which either one will work.
  • rdgrnr
16 Oct 2007 16:25
#176524
Thanks Blue
I went to Kawi and in fact they are the same part #. Now hopefully I can get the one on ebay without getting sniped again..Geez that bugs me
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • Bluemeanie
16 Oct 2007 17:50
#176550
Ain't sniping a pisser? I just try to prevent it from happening to me, I've never done it to someone else..... yet!:woohoo:
  • ten6
  • ten6's Avatar
17 Oct 2007 11:46
#176715
I think I have 2 or 3 airboxes sitting at home now. The rubbers prob aren't any good though. If you are interested we could make a really cheap deal. Let me know!!;)
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • RonKZ650
  • RonKZ650's Avatar
17 Oct 2007 12:08
#176717
The 79 is not the exact same and has a different part number due to the emissions hose nipple on it as bluemeanie mentioned. That can be plugged and it can be used on a 77 just fine. About sniping on ebay, I get so dang angry because nearly every single thing I ever want to buy I get outbid by $1 at the end. I thought it was just me :P
What gets me is there can be an item on there I want but I don't bid and it sells for $50, the next day the exact same item comes up and I bid $100 to be way on the safe side. It will sell for $101 every time! I don't get it.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 13:03 - 03 Dec 2008 07:36
#176730
del
Last edit: 03 Dec 2008 07:36 by JMKZHI.
  • Bluemeanie
17 Oct 2007 15:01
#176747
Ron, as far as sniping, heres what you do! (maybe you already know this, if so disregard) You have your window open always refreshing as you watch the time. Open a SECOND window and have a higher bid already to go, Have one finger hovering over the "confirm" button while you refresh in the other window. Seconds left and you get sniped, if 2-3 seconds left hit confirm button and you've won it! I tjust depends how much time they leave you to hit button. I did NOT do this and they sniped me with 7 seconds left, I could have confirmed and screwed them!! I lost this last week...
  • conpewter
  • conpewter's Avatar
18 Oct 2007 08:48
#176887
There is one sure way to stop sniping. Bid the max you are willing to pay for the item the first time. If a sniper wants to pay more than you'd pay for the item, they'll get it. If they want to pay $10 less than you, then you'll get the item for $9 less than what you'd be willing to pay for it.
  • rdgrnr
23 Oct 2007 04:24
#177750
Thanks all for the input. I did find a nice airbox from a 79 that will work by plugging the emission hole. I am done being a sniping victim. I bid what I'm willing to pay, and if it goes higher, so be it. There seems to be plenty of KZ parts out there anyway.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • rdgrnr
25 Oct 2007 15:49
#178109
OK,
The airbox is here and I'm ready to clean and polish it and should be installing it this weekend. The mount brackets did come with it, but does anybody maybe have a closeup pic of where it gets mounted to? I looked in the book and that was no help:(
With all the wiring, it's hard to tell, but does it get mounted to the battery box?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
