Drilling out jets, where can I find size chart?
- djnubz
04 Oct 2007 15:48
Rather then buying new jets I would like to drill the ones I have. Could someone point me to a chart that shows me what size drill bit equals what size jet? I need a 92 and a 70 jet size and I am not sure I can drill out a pilot jet but if I can I need to know what size drill a 36 jet is.
- jason8887
Re: Drilling out jets, where can I find size chart?
04 Oct 2007 19:58
I don't know if a chart exists since the 'number' on a jet does not mean the same thing between different manufacturers. Keihin jets are numbered different than Mikuni, etc.
A sure fire way to find out is to find someone with a set of gage pins that you can use to measure the diameter fo the hole in your jet. Next, calculate the AREA of the hole of your jet (area=radius^2 * pi (3.14)).
From there, you can calculate the percent increase you desire by dividing the number on the jet you want have with the number of the jet you curently have.
Multiply this number by the area of your current jet, then solve for the diameter that equals that area ((sq. root of (area / pi)) * 2) and you will get the diameter of the jet you want.
Please note: this is just an educated guess, not a verified method of drilling jets!
Jason
Jason
- OKC_Kent
04 Oct 2007 20:12
By the time you figure out the math, find the drill, drill, not f**k it up, and test it....
you could buy the jets from Z1 for a couple bucks each
Cashion, OK
78 KZ650 B2 85,000+ miles
- djnubz
04 Oct 2007 21:16
The parts I need are all special order and I am not afraid to drill out a jet. it's just a small hole that you enlarge.
- OKC_Kent
04 Oct 2007 22:11
Well, it's the best I could do.:laugh:
So find a drill that fits and go one size larger, right..? Use the drill shank as a pin gage, I guess.
Cashion, OK
- OKC_Kent
04 Oct 2007 22:25
OK I can do better.Heres a Mikuni chart. (Tell me you have Mikunis:whistle: )
www.iwt.com.au/MIKUNI.HTM
Cashion, OK
- djnubz
04 Oct 2007 23:21
that is a great find but I have keihins. Thanks for trying though.
- djnubz
04 Oct 2007 23:21
- kz650csr81
04 Oct 2007 23:53
www.dirtrider.net/justkdx/jetneedles.html
maybe this will help
- tjettim
05 Oct 2007 03:25
Drilled jets are not consistent,ever look
at a drilled hole with a magnifying glass?
You will need to purchase the right sized
reemer,and undersized drill.Then you will
have to mark the jets so you don't mix them
up later.It's easier just to buy the jets
if you can.Or you can go all the way,get a
lathe,some brass,a thread cutting tool....
- wiredgeorge
05 Oct 2007 06:05
Tim, You will also need to bevel the hole ends in exactly the same way that Mikuni did to get the correct fuel dispersion. If not, the fuel will come out in a splatter. I believe that drilling jets is a waste of time as you have noted, it can't be done consistently unless you have a drill press and way to secure the jet plus bevel the edge at the correct angle. Not saying it couldn't be done but certainly it isn't all that easy to get right without the correct set up.
- arobsum
06 Oct 2007 10:08
like previously mentioned....most jets are cheap, mistakes are not.
Post edited by: arobsum, at: 2007/10/06 13:08
