BS 34 carbs
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: BS 34 carbs
20 Jan 2006 07:27
#18869
Just did this on friends xs650.
remove slides
remove bowls
remove main jets
remove washers under main jets
look at the emulsion tube (part the main jets screws in to)
you'll see a little slot on one side. make mental note. A pin from the casting extends into this slot.
grab a small dowel or maybe a chopstick and use it as a drift to
push the emulsion tube out throurh the top of the carb(where the slide was) you may have to tap gently on the stick but wood won't hurt the brass or pin if you happen to snaf it.
That's it... clean up tube inside and out and clear all the small holes clean the casting on the inside and maybe remove the small jet under the rubber button to make sure passage between it and main jet is clear. I used a pipe cleanet.
Wen you put it back together, the main jet emulsion tue should slide in easily. Be mindful to fit the slot in the side over the pin in the casting.
Don't forget the washers when you put the main jests back in.
Don't forget the small tab on the slide diaphragm wne you put the slides back in. Use a little vaseline if the diaphragm doesn't want to stay in the grove.
-Duck
  • fergyfer
  • fergyfer's Avatar
Re: BS 34 carbs
20 Jan 2006 08:59
#18882
My KZP didn't idle well until WG balanced the carbs and we adjusted the air mixture screws afterward. It idles wonderfully now.
I assume you figured out why the slides wouldn't close when the throttle was down...
Sync the carbs and then use the air screws and idle stop screw to adjust the idle. It should idle smooth after that.
  • tw..
  • tw..'s Avatar Topic Author
Re: BS 34 carbs
20 Jan 2006 09:04
#18884
Thanks Duck. You have helped me out BIG time. I really appreciate it. I'm no longer scared of working on carbs. I'll post the results of this final cleaning on tuesday.
tw
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • tw..
Re: BS 34 carbs
20 Jan 2006 09:10
#18885
yes i figured out the slide issue. These carbs were much easier than i thought them to be.
2-1976 KZ900 A4
1978 Z1R
  • tw..
Re: BS 34 carbs
24 Jan 2006 06:05
#19606
I did it. I cleaned the emulsion tubes, some holes were clogged and new the bike idles perfect.
Thanks everyone for your input.
tw
2-1976 KZ900 A4
1978 Z1R
