78 kz1000 ltd carb setup
- wiredgeorge
08 Sep 2007 10:27 #169376
by wiredgeorge
Replied by wiredgeorge on topic 78 kz1000 ltd carb setup
I have tested the jetting combo I already suggested with both K&N pods and Emgo pods... doesn't seem to make a difference. The carbs you have sound like 78 1/2 KZ1000A2A with the 102.5 main jets... In any case, the jetting I suggested will work fine...
- krazyjay99
08 Sep 2007 10:59 #169386
by krazyjay99
Replied by krazyjay99 on topic 78 kz1000 ltd carb setup
great then im on it. I appreciate the help i have the 110 mains already just trying to locate the 20 pilots looks like im gonna have to order those as my local guys dont have the right ones.
- krazyjay99
08 Sep 2007 19:03 #169459
by krazyjay99
wiredgeorg i almost forgot what is a good start point for the air screws, i ordered the jets from z1 when they come in I will be ready to go.
- Rweber51
25 Sep 2007 18:29 #172847
by Rweber51
Replied by Rweber51 on topic 78 kz1000 ltd carb setup
Well in my book wg is the guru. I'm running 17.5 pilots with 130 mains, air screws at 1trn out, dyna coils/ign,vance and hines pipe and K&N filters. What really helped me was wg's repowered coils instructions. She's a screaming ape now.
- krazyjay99
26 Sep 2007 02:17 #172899
by krazyjay99
After a lot of tunning and changes im now at 120 pilots and 117.5 mains with screws at 1 turn and im about set. The dyna coils and ignition module is next to finish the setup. WG said start with 110 mains, and i ended up at 117.5 not sure why such a diff but im there. My plugs are burning clean and the transition is smooth through the throttle.
