Smoothbore identification
- racer54
25 Aug 2007 22:37
I may be wrong on this but I seem to remember I saw a picture of some stock carbs that look alot like 29 smoothbores. Is that right? If so, how can you tell whether you have real smoothbores or a set of the look-a-likes? Is there a part number, casting mark, or another identifiable feature to be sure of what you have?
- Mark Wing
Re: Smoothbore identification
25 Aug 2007 23:16
The float bowls have a caped opening on the bottom of the bowls so you can change main jets without removing the carbs and most of all when the slides are at full open there isn't a hole in the top of the carb body for the slides just a circle cut that the slides go through giving them a "smooth bore" at wide open.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- racer54
26 Aug 2007 00:11
The carbs I seen had the cap on the bottom of the float bowl but weren't 29's. As far as inside the carb, I couldn't tell. The reason I'm asking is that I bought a parts bike and it looks like it might have either this stock type carb or it has smoothbores on it. I could be so lucky! LOL It's a piece of junk for the most part but it has possiblities, especially if these carbs are the 29's.
26 Aug 2007 05:38
Smoothbore has a jet block over which the throttle side moves up and down.
Viewing from underneath with float bowl removed, there is a small phillips head screw holding the jet block in place.
MEMO: Wiredgeorge cautions against removing the jet block as it invariably damages the delicate thin no-longer-available-virtually-impossible-to-duplicate gasket between the jet block and the carb body.
My 29's are as pictured on Z1E site, single large drain screw on bottom of float bowl, only a single fuel line attaching to a single fuel pipe joint located between the two inside carbs, and no accelerator pump.
26 Aug 2007 06:07
Am having difficulty posting an exploded view of the VM29 smoothbore.
These links supposedly go directly to the exploded view.
click on thumbnail
click on see full size image
the view
Post edited by: Patton, at: 2007/08/26 09:33
click on thumbnail
the view
26 Aug 2007 06:27
If image is too small, try clicking on it which may show a button to click to expand the size.
Post edited by: Patton, at: 2007/08/26 09:38
26 Aug 2007 06:48
Part numbers:
See above posts for help seeing the exploded view diagram.
87 = Jet Block
88 = Gasket
13 = phillips head screw
Were you able to get the exploded view diagram okay?
87 = Jet Block
88 = Gasket
- The Fish
26 Aug 2007 07:38Please Log in or Create an account to join the conversation.
- racer54
26 Aug 2007 09:32
Forgot about the difference in fuel line. That should be a give away alone. Going to check them out today so see for sure. Appreciate the info.
- PLUMMEN
26 Aug 2007 09:38
the floatbowls are not always a good way to tell
this bike has a set of 29s on it with tops and bottems off of 26s without the drains to make people think theyre 26s from back in the sneaky days.
- arai59
- Visitor
26 Aug 2007 19:25
29's are unmistakable......just like the 33's.
- BlackStar
28 Aug 2007 18:53
The 29's I used to have also had the idle speed screw pointing up.
BTW I checked with Sudco this May on the jet block gaskets. They assured me they had them both via email and over the phone. It may be worth checking again?
1978 Suzuki GS1000: Indexed,trued, welded crank, 1085 kit, Mikuni RS34 carbs, K&N pods, V&H 4-1 with comp. baffle.
2005 Yamaha Roadstar Warrior 1700: Patrick Racing Big Air Kit, Speedstar 2-1 exhaust.
