'82-'83 GPz550(TK26) Satge 3 Jetting Information Wanted.
- CoreyClough
- GPz550 Addiction
Re: '82-'83 GPz550(TK26) Satge 3 Jetting Information Wanted.
30 Jun 2007 08:11
Funny, their instructions for the jet kit install say just that,
2. Use the slide drill (DD #7/64) provided to enlarge the slide
lift hole (Fig. A).
No way!!! Stop the insanity!!!
lift hole (Fig. A).
'85 GPz550(ZX550-A2)
- loudhvx
30 Jun 2007 16:05
The slide lift-hole is the offset hole. That alters the lift rate.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- CoreyClough
- GPz550 Addiction
30 Jun 2007 16:37
If someone didn't know any better, they's drill out the center hole like it says, not the offset hole. I bet someone's done that. :blink:
- CoreyClough
- GPz550 Addiction
02 Jul 2007 10:31
Because the Dyno Jet Kits use to be K&N Kits, it looks as if the copying of the pictures is the only problem. The full picture here is of the K&N Stage 1 & 3 Kit from a '84-> Gpz550:
The one below is of the Dyno Jet Stage 1 & 3 '82-'83 GPz550:
I've added the arrow to the offset hole in the second picture above, but it looks as if the picture's been cut off. from the original
Don't enlarge the center slide hole.
The center slide needle hole is smaller than the #32 drill bit supplied, and also larger than the offset hole.
Post edited by: CoreyClough, at: 2007/07/02 13:35
- loudhvx
02 Jul 2007 10:42
Yeah, they really dropped the ball on copying the instructions. That will screw up some folks for sure.
Thanks for the clarification.
1981 KZ550 D1 gpz.
Other links.
Other links.
- dav231481
23 Jan 2013 05:46Attachment 2013-01-2316.18.591.jpg not found
Hi. Im about to rejet mine for pods and 4-1. what would happen if i didnt drill the offset hole and should my throttle cable bracket have this curve in it. The throttle sticks open, cable in line is slack but revving @ 3-4 K
- CoreyClough
- GPz550 Addiction
23 Jan 2013 09:49
I asked Dynojet that same question and this was their reply:
Enlarging the slide lift holes, make the slide lift faster for better throttle response. If they are not modified as the instruction say, the gains will not be as good as they should be and the needles may need to be adjusted.
Looking at your picture, that really needs to be fixed before you put those carbs back on. :blink:
The following user(s) said Thank You: dav231481
- dav231481
27 Jan 2013 04:03
spoke to a local dynajet technician who advised me to be very careful when taking US related jet sizes as it seems your fuel is a different formula to ours over here and is a bit stronger. On his adevice Im going to keep it stock for the time being with standard airbox and just richen up the needle for the 4-1's. Thanks for your help. Im now trying to source new needle jets and air ducts.
- donthaveakawman
27 Jan 2013 07:07
you aren't swapping your jets for his are you?
