Eh, who needs jets and screws anyway...?
- RonKZ650
Re: Who needs air screws, anyway?
21 Jun 2007 15:12
You have those junk transition carbs. (Sorry for the bad words). I doubt anyone in the world knows how to tune those. According to Kawasaki they say turn the pilot screws (4 adjustments on the bottom of the carbs) all the way in, then turn the air screws out 2 turns. I question this procedure, but that's what they say. Assuming all those parts in your picture did actually come from your carburetors. I don't see the pilots or main jets were replaced. Sounds like one of your pilot jets is clogged.
- Voodoosoup
21 Jun 2007 16:50
BSKZ650 wrote:
From NGK's website "For Japanese manufacturers (NGK, Denso), the higher the number, the colder the plug."
NGK lists the B7ES as the stock plug for 77-79 KZ650B, C's etc..
Under my seat it lists B7ES, my Clymer says B7ES etc...
you said you put B7ES plugs in, it should have B8ES, you are running a colder plug, it may not be firing correct with that plug
- Virii
- I like cheese
21 Jun 2007 17:06
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- Virii
- I like cheese
21 Jun 2007 17:11
- Virii
- I like cheese
21 Jun 2007 17:12
- Virii
- I like cheese
21 Jun 2007 17:13
- Virii
- I like cheese
21 Jun 2007 17:21
I had thought they were VM 24
Dirty.....Don't know this fitting.
Carbs were synced, or so I was told. I should have just insisted I could do it myself. Then at least I'd know these carbs intimately...
So I'm going to adjust fuel and air screws, then pull and clean thoroughly otherwise....or is the suggestion that I get different carbs? I'm unfamilliar with the reference "transition".
Post edited by: Virii, at: 2007/06/21 20:23
- BSKZ650
21 Jun 2007 17:22
I am going thru the carb issue deal, the carb you show looks like the ones I have on the ltd1000, according to wg, they are off a suzi, and a pain in the butt to make run right.
I will look at the book, the lower the number the colder the plug, I am running 7s and 6s in the race cars, we run high rpm and lots of compression, so it takes a cold plug to keep the preignition away
77 ltd1000, current rider
76 kz900, just waiting
- The Milkman
21 Jun 2007 18:43
Champion and everyone else I know of numbers their plugs, the higher the number the hotter the plug, for some reason NGK does just the opposite the higher the number the colder the plug.
Ride safe.
Ride safe.
- The Milkman
21 Jun 2007 18:47
My memory must be slipping, I thought I was told the fuel screws (the ones on the bottom in front only get turned out 1/4 of a turn. Me bad.
Ride safe
Ride safe
