Carb ID - '79 KZ1000 (Not Original)
- arozanski
Any guesses as to the type of carbs I have?
- wiredgeorge
- arozanski
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- wiredgeorge
- arozanski
- daxx
hate to jump in but i'm in the same boat.
wiredgeorge...my carb #'s
p9
61
tia
scott
- wiredgeorge
claxx - get the number from the other side. Later sets of carbs had the ID marks ONLY under the choke side and your number is a carburetor part number or something and not the ID mark... the OTHER number will start with a 1xxxx likely and that will be the ID mark. Also. what type of bike are they on? MOST of the carbs that carry the carb part number on the non-choke side are VM24s and will have horizontal bands running across the carb bodies.
- arozanski
- wiredgeorge
- arozanski
Those are 1976 KZ900A4 carbs; VM26SC: #115 mains, #17.5 pilots 5DL31-3 jet needle and 258 O-6 jet needles - These are the best of the lot as far as VM26s... not affected by EPA mandates at this point and plenty rich. Not much needs to be done with these carbs for rejet if you put on pods or a 4 into 1... just #120 mains. Leave the rest alone. They sync mechanism is a bit complicated but works well once you understand it.
Thanks! Amazing what info you can get from those little numbers
They already have 120's in them. Believe me, I don't want to mess with them any more than I need to.
Now, another question - I purchased rebuild kits for a '79 KZ1000A, I assume something is different? The gaskets worked fine, but what about the inlet needle and seat? Should I get new kits?
- wiredgeorge
