Building your own carb sync tool--source for gauges
  • Skyman
  • Skyman's Avatar Topic Author
30 Apr 2007 09:06
#135624
I have been considering building my own carb sync tool using four vacuum gauges. A while back, someone here posted a link to an E-Bay seller that sells the gages cheap ($3.50 ea).
But I hesitated because I could not find a source for the damper valves. I saw some people here posting suggestions for making your own dampers. While I'm sure they worked fine, they just seemed a little hokey to me, and I wanted to find a more "elegant" solution.
So I kept looking for damper valves. Couldn't find them. So finally, I just wrote the company that sells the gauges on E-Bay and asked them what they recommend.
They told me that for $0.75 extra each, they could put a plug into the gauge orifice that would take care of the needle vibration. :woohoo:
Problem solved.
So I just ordered these gauges today. We'll see how they work when I get them, but I wanted to just post a link to this company's E-Bay store in case anyone else here is looking to do the same thing.
stores.ebay.com/NOSHOK-Direct
So far, I can say that they have been very helpful and responsive to my requests. I'll post more when I actually get the gauges.
West Linn, OR
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Apr 2007 09:11 - 03 Dec 2008 11:43
#135626
del
Last edit: 03 Dec 2008 11:43 by JMKZHI.
  • vach
  • vach's Avatar
Re: Building your own carb sync tool--source for gauges
30 Apr 2007 09:46
#135637
You can't beat the price though. Individualy those gauges are $25.00-$40.00.
I would make these. The full set on E-Bay is always $50.00 to $125.00. for the real synchronizers. Just get the dampers from them. Sweet deal.
1979 kz650 B. Chicago, Illinois
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Apr 2007 09:56 - 03 Dec 2008 11:44
#135642
del
Last edit: 03 Dec 2008 11:44 by JMKZHI.
  • Skyman
30 Apr 2007 10:31
#135654
JMKZHI wrote:
What was the shipping charge? I've considered getting some of their gauges but will probably get ready made carb sync tool (I'm gettin' tired of making tools n' jigs). JMK.
Gauges: $14
Dampers: $3
UPS Shipping: $9.05
Total: $26.05
Post edited by: Skyman, at: 2007/04/30 14:06
West Linn, OR
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Apr 2007 11:58 - 03 Dec 2008 11:45
#135674
del
Last edit: 03 Dec 2008 11:45 by JMKZHI.
  • Skyman
09 May 2007 13:37
#138611
Update:
I received my gauges from Noshok. I mounted them on a metal bar, attached hose barb adapters and vacuum hoses, then hooked them up to my carbs.
Worked like a charm! I was able to get my carbs dialed in so that they are now synchronized.
West Linn, OR
  • Robjb84
  • Robjb84's Avatar
09 May 2007 14:29
#138625
pictures or it didnt happen!
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
11 May 2007 22:40
#139326
Okay, I went to the web site (and thanks for that!), and I hate being 'needy', but could somebody tell me exactly which of those gages to get...there seem to be several options and I'm not 'dialed in' (pardon the pun) on which one I need, exactly.
Next question: are they better than my mercury sticks?
Thanks for the help!!!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
17 May 2007 22:56
#141153
"bump"
Need a little love here...which ones do I buy off that site?
Thanks!
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • The Milkman
  • The Milkman's Avatar
17 May 2007 23:25
#141157
On about the 3rd page of that site they have vaccumm guages of different physical sizes,, ie: 1.5'" 2", 2.5"
any of them will work.
I also noticed they have 0 to 15 PSI. pressure gauges, can anyone say OIL PRESSURE,, for the same $3.40 :woohoo: :woohoo:
  • Skyman
17 May 2007 23:31
#141160
-KR
These are the ones I bought:
item 7625997565
Be sure you contact the seller before or just after the sale to tell them that you want to have them insert the small orifice to reduce needle vibration. They will charge you an extra $0.75 ea for this.
Post edited by: N0NB, at: 2007/05/18 10:57
West Linn, OR
